Am I using this Zbox properly?
Rhetro
Post by Rhetro »
Hello.
Just got a Zbox in the interest of attaining something closer to what I would see/hear if I miked an amp and/or went through its output.
I tried two different channels set on a clean setting: One with the Zbox, the other without. Playing pretty much with the same dynamic force in both strumming and soling on both tracks. I tried using the same notes and the same area of the neck (just scale stuff). On playback, I notice NO difference. There was no difference in the wave form either. What am I doing wrong?
iMac (3.06 GHz Intel Core 2 Cuo, 6GB/800 Mhz), Macbook (2 GHz Intel Core 2 Duo, 3 GB/667 Mhz) DP7.24, IZotope Ozone 4, Presonus StudioLive 16.4.2, Dynaudio BM 6A mkII, Yamaha NS-10M Studio, JBL 4311, one Auratone 5PSC, Alesis RA-100
magicd
Re: Am I using this Zbox properly?
Post by magicd »
The ZBox is an impedance adaptor for passive guitar pickups. It will make a difference if you are plugging a high impedance guitar into a low impedance input.
If your guitar has active pickups, the ZBox won't make any difference.
If what you are plugging the guitar into has very high impedance inputs, the ZBox won't make any difference.
What is your signal chain? What kind of guitar into what input?
Dave
Rhetro
Post by Rhetro »
Thanks Dave!
This makes sense.
Ok, I have an old Steinberger GL4T (one of the old white ones) going into an RME Babyface.
magicd
Post by magicd »
The specs for the Babyface describe a HiZ input for instruments. They don't give a specific impedance measurement, but if the impedance is high enough, that would mean there is no need for the ZBox when using that input.
Dave
Rhetro
Post by Rhetro »
Thanks for checking it out, Dave -really, above and beyond!
That would explain the two tracks being so similar!
I guess there's no advantage to using the Lo-Z on the Zbox in my case. i.e., tweaks, experiments, etc.
Trying to think of a reason for keeping it. But I may as well return it since I just got it. Unless....someone can think of a reason???
You've been great!
cheers
kgdrum
Post by kgdrum »
That's why his real 1st name is Magic ;-)
Kurt Cowling
Post by Kurt Cowling »
So would the Zbox be helpful plugging a guitar directly into MOTU's HDX-SDI? I assume those inputs are not "instrument" inputs.
Thanks for any insight,
--Kurt
DP 11.34 , 2021 MacBook Pro M1-Max, 2017 iMac Retina 5K 27-inch, Omnisphere, Trilian, Stylus RMX, EZ Drummer 2, Falcon, Real Guitar, Sample Modeling brass. Audio Modeling reeds, strings, Kontakt 6, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, PSP Impressor, Altiverb 7, Izotope RX10 Standard, Yamaha S-90ES, Yamaha MOXF-8, Yamaha MX60, Sibelius subscription, Adobe CC and Motion 5.
