reapr win7 ultralite mk3 record main output
proto
Post by proto »
Hi,
I really like how the mk3 colors my guitar signal,and I'm trying to print it or record it on my track.
when i click on the outputs tab <in cuemix> i can add these dynamics. but this doesnt print the effect. when i add the dynamics on the input section of cue mix, it sounds not nearly as good.
how do i print or record the dynamics in ?
in the reapr audio preferences, it allows for input analog 1-8, spdif 1-2, return 1-2 and reverb 1-2.
this routing seems kinda convoluted? if someone could point me in the right direction id be really thankfull.
thx proto
RonaldDumsfeld
Re: reapr win7 ultralite mk3 record main output
Post by RonaldDumsfeld »
If I understand your question correctly mate you should be able to use the MOTU Audio Console to assign Returns 1 & 2 to whatever output pair you are using and record from them direct.
Alternatively loop back your preferred wet output, probably best via SP/DIF.
