Waves 7 & DP 7.24??
tommypenngotti
Waves 7 & DP 7.24??
Post by tommypenngotti »
Is Waves 7.0 compatible with with DP 7.24? I see it in the audio plug in prefs (enabled all) , but Not showing in insert channels? Thanks
DP 7.24
Mac Pro 2.66 Quad Core Intel Xeon / 16GB
Waves 7.0
Mac Pro 4,1 2.66 GHz Quad Core, 16GB Ram, OSX.7.5, Dual Cinema Displays -ATI Radeon 5770, Motu 896/828MK II DP 8, Waves v9
Re: Waves 7 & DP 7.24??
tommypenngotti wrote:Is Waves 7.0 compatible with with DP 7.24? I see it in the audio plug in prefs (enabled all) , but Not showing in insert channels? Thanks
DP 7.24
Waves 7.0
That's what I have. It works fine. Don't know if Waves 7 works with Lion though. With OS X version are you using?
tommypenngotti
I'm using Lion 10.7.4 :?
Seems if they all appear in the DP pref general/audio plug in area , then why not in the insert ? :banghead:
tommypenngotti wrote:I'm using Lion 10.7.4 :?
Did you upgrade to Lion after you installed the Waves plugins and had DP so the AU validation? If so, maybe they appear in the preferences from when you used SL. There is a procedure to re-validate the plugins. Can't recall what it is.
More: Google "Waves 7.0 and OS X Lion". Says you need V8 for Lion. One more reason to stick with SL for audio.
tommypenngotti
I had Lion in and then installed Waves 7 , weird to see it in prefs but not inserts , thanks for the Lion info , bummer
Too bad. You have to keep a close eye on Waves compatibility. They're really fussy about OS versions.
noomi
Post by noomi »
Hello Motu users,
My 24 I/O was exhibiting a 250 mV DC offset at the inputs which causes scratchy pots and switches downstream when connected to the direct outputs of my analog board. I sent it back to Motu via RA for their $100 exchange program. However, the replacement unit has the same issue except that it's only 132 mV DC offset but that's still enough to cause noisy pots and switches.
Latest JN0-660 dumps practice questions delivers in depth understanding so you will pass real exam on time. Also see more details on University of California, San Diego and Anabaptist Mennonite Biblical Seminary website and Youtube or Facebook best of luck.
