New drivers 4.0.5.3503
Re: New drivers 4.0.5.3503
Have somebody tried new driver with i7 P55 64-BIT Windows based computer for PCIe-424 AUDIO? Due my computer being racked it's not reasonable to take it out from rack just to get known that new driver still does not work.
Thaks for your efforts in advance.
Hi and welcome.
I don't understand. Why would you have to take the machine out of the rack to install a driver?
Do you mean that you'd have to remove it to re-install hardware or something?
Before reinstalling driver you have to remove PCIe-424
Nah, just go right on it and install the driver.
How do I tell what version the driver I have is?
There are many ways. The simplest is to open MOTU Audio Console then look at bottom of the app.
Hey, is anyonachieving any problems with this driver?
I got a new microbook 2 and when installing it it also updated my 828 mk3, of course...
And now I cannot change my sample rate from inside sonarx1d.
I can change it from the Motu audio setup app just fine but not from within the software
Win7 64bit,
Any thoughts?
Win7 64bit,
Any thoughts?
It's all well and good here.
Start a completely new project in Sonar and see how it behaves like that. Don't import anything at all from previous projects, for testing purposes.
Make sure Sonar is set to use the proper ASIO input and output, instead of other.
It works! With my i7 Gigabyte GA-P55A-UD4 Windows 7 64bit!!!
But another problem is new CueMix. I can not find the way to change output for mix. The upper menu sometimes does not work. And I could not find the reason.
Have anybody met problems with this new version of CueMix? The promo at MOTU site shows some another look of the program.
New version of CueMix?
What does that bring to the table?
Thanks in advance.
Thanks in advance.
Bredo Myrvang
The Sound Residence
Oslo, Norway
The Sound Residence
Oslo, Norway
CueMix is not compatible with Ableton Live 8.
I can't tell if it was compatible before this update as I am a recent buyer of a MOTU MicroBook II.
Please see the following post ...
http://www.motunation.com/forum/viewtop ... 14&t=50437
That's strange. People are using new driver and nobody has made an attempt to run CueMix FX? Just compare the demonstration of CueMix in the description of Audio PCI-inerfaces and the one yoy have installed with driver. Find a difference
