DP 7.24 here
I've been saving multiple mixes of the same project. I can't open any of them. It'll roll for a bit and then the wheel comes out...(app not responding).
I can play other projects/mixes but not this one.
Very important song and I can't lose all that work.
How do I get it to play?
jb
Can't play a file
- Dan Worley
Re: Can't play a file
Any number of things could be the reason for this problem, but the most likely is a troubled plug-in. A corrupt soundbite is also quite possible.
First things, if you haven't already, make sure you restart your Mac. That can quickly make a lot of problems go away.
Try loading the problem sequence and its files and settings into another fresh project (File > Load). Look to the manual for particulars on using the Load command.
If it doesn't work, use Load as a troubleshooting tool to narrow down the problem by loading or not loading certain things.
I've had a few times when it took three or four crashes using Load before it finally broke through whatever was making it crash and it worked.
Good luck.
Good luck.
DP10.13
Got it!
I disabled all tracks in tracks window. Hit play and then enabled each track while project played. Intermittently hit save. Was waiting for a track to crash the project, but it didn't happen.
