Stuck MIDI Notes
- pencilina
Stuck MIDI Notes
Hi,
I'm using 4.6 on a dual g5 running 10.3if it works don't tix it.8 with a MIDI express 128 and usually no VIs.
I've been experiencing some really annoying note sticking in my otherwise calm cool system
I did a search and found no real answers.. only more questions (woo wooo<- in search of theme)
Some interesting facts:
-DP's panic (all notes off) ain't doing s&*t
-if I reset (turn off) my keyboard/module (Alesis qs 7.1) the stuck note/s come back (WotTF?)
-If I play the same notes the stuck notes still stick
-If I quit DP (or sibelius for that matter) this usually doesn't help
-My solution is usually to restart
-On one recent restart I had to unplug and plug my MIDI express to make it reappear
it seems like the problem is core MIDI related
Any suggestions?
Thanks in advance
Any suggestions?
Thanks in advance
- iMAS
Re: Stuck MIDI Notes
Well, I've had MIDI stuck notes before and it somehow went away. Well, it just returned today...and I'm in the middle of a deadline !!!!! NOT COOL !!!
I had stuck notes before the 1.3.1 drivers. This update fixed all my problems on 10.3.x. Now I'm on 10.4.2 and i have no more stuck notes...
a lot of VI and MIDI......
sorry for my english...
[/i]
Frank
G5 dual 2.5 4.5G RAM,PCI424 2408+1224,DP 4.6,Reason3,Mach 5,MX4,Zebra,Albino 2,Ivory,DFHS,UAD-1,Waves,PSPVW
- iMAS
Interesting. Well, when the "MIDI stuck" note rears its ugly head...I just quit DP, turn off my sound modules and the mtp/av...and then turn everything back on....it works for me, at least.pencilina wrote:stuck notes suck
my temp solution - open core MIDI setup page and go into test mode then click on the sticking device a few times. Saves a reboot. Let me know if that works for. I think its a core MIDI issue. BTW what's your system version and MIDI interface?
Maybe you're right , it could be a core MIDI issue...because once after I pressed the panic button, the stuck-note stopped...but I lost all MIDI connection (like someone just pulled out all the MIDI cables). I don't recall MIDI stuck notes occuring when I'm using only VI's though. The good news is that it's not occuring very frequently.
Stuck notes
I've had tons of stuck note problems with Tiger, anything connected to MIDI IN on the Fastlane and the latest MOTU OS X USB drivers. I get stuck notes in DP 4.52, DP 4.6, Pro Tools 6.9.2 and standalone right into Native Instruments VIs. DP is essentially unusable for recording MIDI tracks in this setup.
Using a Yamaha S90 connected by USB as a MIDI input device I have no problems in DP, PT or standalone VIs. My verdict: either the Fastlane or the MOTU OS X USB drivers for Tiger are the culprits. CoreMidi patchthru on/off doesn't make any difference. If I had to place a bet, I'd say it was the MOTU drivers.
Jason
Jason
- dynamix
RETURN TO THE WALKING DEAD TOPIC
Just reporting that this Zombie is still rearing its ugly head.
Tried Pencilina's suggestions but can't seem to test virtual instruments.
So I'm just quiting and restarting the program.
Will try DP DAN'S Suggestion. but first gotta finish this project. No updates in the middle of a project thankyou...
BUT HERE'S THE MAIN THING.
It only seems to happen when I'm SCRUBBING MIDI NOTES. GOT THAT MOTU??? HELLO, ANYBODY OUT THERE?
sorry for the rude tude...
Back to my deadline
Erik
_________________
Back to my deadline
Erik
_________________
http://www.dvbmusic.com
Dual 2 Ghz G5, MOTU 896, OS 10.3.9, DP 4.6, Mach 5, Kontakt 2.2, MX4, Reason 3.0.5, GPO, Absynth 4.0.2, B4 Organ II 2.0.3,. MacBook Pro 2.33 GHz Intel Core 2 Duo - 4 GB 667 MHz DDR2 SDRAM w/ MOTU Traveler & MOTU Bag w/ OS 10.4.10, DP 5.12
- npatton
MOTU is aware of the scrubbing MIDI problem. Be sure to send them a detailed description of what you were doing and what you were using (hardware/software) when it happened. My last interaction with them on a related scrubbing problem did yield a "we've-duplicated-the-problem-and-we're-passing-this-on-to-the-developers" response. We'll see what happens, but at least we're this far...
n
n
- yofo
My system has been running great but then today all the sudden, every time I stop play I have stuck MIDI notes.So I Quit DP and then started it up again and that fixed it ( for now ? ) Anyone got a clue what that was ?
Mac OSX 10.6.8 2 x 2.66 GHz dual-core Intel Xeon 8GB 667 MHz DDR2 FB-DIMM RME Fireface 800
