Transport & Basic Sluggishness???
tommypenngotti
Post by tommypenngotti »
Powerbook G4
Ram 1.5 gig
60 gig HD
DP 4.5
buffer size 512
I seem to be experiencing alot of visual latency w/ DP .....the trasport is "jittery" & all the faders LED's are jerky? I thought my new memory venture would cure this going up to 1.5 gigs??
dmshep
Post by dmshep »
You didn't mention the processor speed on your Powerbook. After a certain point, it seems that memory doesn't make a difference. When the processor is maxed, it's maxed, and you'll get the sluggishness and jittery visuals. I know with our dual 1.25Ghz G4 we've got 2 GB of memory, but when I get the plugs and track count high enough, all the overload symptoms start to show, and I'm still only using about half of the available memory.
I don't use VI's though. Perhaps extra memory is helpful in that regard?
David
tommypenngotti
it's a 1 GHz power pc G4 Processor....contemplating just getting a G5 dual 2.7 ghz processor, my friend has one & claims there isn't any visual latency
David Polich
Post by David Polich »
Go for the G5. That's really what DP works best on.
I have a G5 dual 2.3Ghz. No sluggish UI response here.
croyal
Post by croyal »
did you optimize the os? Do a search for "Optimize OS X" on this board for tips on configuring. Also do a web search for "Tracking the Big Cats" article from Elec Musician and few months ago. The author was ale to get 50 or so tracks at 24/96 on a powerbook. Even 1/2 that many is pretty good for a powerbook at 24/96. The RAM you added will really help.
Don't ignore the last part of what you'll find, which is to defrag the OS disk. That last step is what really makes everything fly, I've found.
Mac Studio Ultra/ 2013 Trashcan. DP10 and 11.
32 channels of Apogee Symphony MkII/ Dangerous 2Bus+.
Lots of Neve, API, and Dangerous outboard gear.
boonier
Post by boonier »
right this really gets my goat...
so are you guys suggesting (and MOTU) for that reason that any computer older than 3 months is basically below system requirements for DP 4.6?
I bought a PBook 1.67ghz with 1 gig ram and about 3 months ago loaded with 10.4.2. I think this is currently the top of the line powerbook that apple sell. Is this now too slow???!
I also made the transition from Logic to DP, because it was a choice between 'everything' Apple or a 3rd party. I dont really like Apples tactics as a company with its forced market approach. Audio units and core audio woohooo! Like how much better are we for it? We were just forced to update Anyway, I digress....
I cannot fault DP for its features and overall depth, but when it comes to smooth workflow, I find DP is absolutely pedestrian.
I sure theres some serious problems going under the hood here in 4.6. My 300mhz G3 in os 9.2 ran snappier than this. I'm talking visually here, not with the quantity of plugins and tracks it could run. Sometime this is more important than anything, like when you have a sudden flash of inspiration but your waiting for the screen to refresh. Sure the spinning colour wheel is pretty but not when you've nudged a soundbite left a 16th note for the 6th time (maybe a bad example)!
basically I'm venting and trying to come across as constructive here!! I've just spent a lot of money upgrading everything thanks to Mr. Pomme, and i've never spent so much time optimising a computer and checking forums for solutions.....in fact i cant remember the last time I actually wrote some music :wink:
come on Motu sort it out! in the meantime wheres my ukelele.......
tommypenngotti
powerbook
I hear ya , I've had 3 Powerbooks & now G5 on the way ...trying to keep up !! My thing is it all comes down to what bothers you & what it's worth to rectify the problem. I have a friend who uses DP 3.0 on a G3 iMAC (mostly out of fear of updating & losing his vibe) & gets great end results. I personally am more "new gear" oriented & love the tecnologic advances , I also hate latency & sluggish response!! :evil:
I friend told me yesterday that Pro Tools has a different architechture that allows it to run smoother than DP....I would hope MOTU is on this & striving to beat all competitors
bitmaniac
Post by bitmaniac »
i remember reading that DP 4 was simply a port to OS X and had pretty much zero optimization. the optimization was due to happen in the next revision. did that ever happen? doesn't seem like it.
boonier
Post by boonier »
bitmaniac wrote:i remember reading that DP 4 was simply a port to OS X and had pretty much zero optimization. the optimization was due to happen in the next revision. did that ever happen? doesn't seem like it.
If thats the case, then they must be up to something.
I havent heard a peep from anyone on this forum with regards to what they might be upto. Maybe its coming in the 4.61 revision......they're keeping tight lipped so as to not promise anything they can't deliver..i really hope so
There some pretty extensive bug sheets - enough to keep the developers busy for some time i rekon
The DYnamic CPU management thing introduced in 4.52, whilst being a damn good idea, may have been a 'temporary' fix to alleviate the lack of optimisation.....although this risks sounding like a conspiracy theory :D
tommypenngotti
Mission Solved!
got the new G5 2.7 / 2 GB ram & the tracks (30 trx w/ 20 or so DP FX) are flying now!! Don't even have the internal drive yet (which I plan to acquire soon)
thanks 2 all that helped w/ advice
MR Booth
sluggish
Post by MR Booth »
I am experiencing the colour wheel for long periods of time too. I am in the process of updating "everything" and have updated to DP 4.6. However it won't open any old files so I'm using 4.5 (.2?) and that's sluggish. Now I suspect this is because I'm running a G4 (g3 300 ... processor) and 512 ram. Right???
Will an increase in Ram make any difference or should I just hang out for a G5?
By the way 4.5 wouldn't run with 4.3 sharing the hard disk. Maybe it's the same with 4.6. sharing with 4.5
Mike
sdfalk
Post by sdfalk »
Magic dave has suggested (On many occassions on this forum)
to set "work priority" to medium for powerbook users.
Apparently this solves some problems using Powerbooks
with DP.
Have you tried that?
Also, no you don't need a G5 to run DP.
That's ridiculous.
I've run it on a 667 mhz Powerbook.
Properly setup and configured it was recording 16 channels of
24 bit audio on an external Firewire drive with no problems.
A Metric Halo ULN8-3D…mmmmmmm
boonier
Post by boonier »
sdfalk wrote:Magic dave has suggested (On many occassions on this forum)
with DP.
That's ridiculous.
hi
I'm using a Edirol Fa-101 and I have to set my work priority to Low....
If I set it to Medium it goes all fuzzy, high is even worse, which is why i keep it Low.
any ideas why this might be?
I would have splashed out on a Motu firewire interface, but I didn't have the beanz at the time..
ps. Sdfalk - thanks for the big up recognition on my freeze tracks tip! your all such nice considerate people. Glad you like my layman approach there :wink:
sdfalk
Post by sdfalk »
I wish I did
Has Edirol given you any input on the problem?
"ps. Sdfalk - thanks for the big up recognition on my freeze tracks tip! your all such nice considerate people. Glad you like my layman approach there"
Well..in many respects I'm still a layman myself.
You're insights are as valuable as anyone elses.
I noticed the front panel has (what looks like) adat connections.
Is it possible to disable them in software when not in use.
I'm (obviously) guessing, but maybe that would free up a bit of CPU?
Also have you flipped around different sample rates to see if the
problem continues?[/quote][/b]
boonier
Post by boonier »
sdfalk wrote:I wish I did
not really, just says its 'out-of-the-box' compatible with osx 10.3 upwards and
even goes through installation in DP in the manual...
freaky, there a fresh topic just started about the fa-101 literally now...how mental is that??
