Free-running Oscillators
KenNickels
Post by KenNickels »
Is there a way to de-couple the ADSR from an oscillator so that it goes forever without having to retrigger it or to trigger it at all?
My Box(s): Two Mac Pros 5,1/3Ghz, 12 core, 96GB Ram, OS 10.14.6, One Windows 10 computer, Vienna Ensemble Pro, MOTU Audio Express, DP 10.01, Falcon 3, Eastwest, NOVO Strings, 8Dio Brass, Spitfire,, Symphobia
hugy
Re: Free-running Oscillators
Post by hugy »
But how would you stop it then ?
If you don't want to hold the key then you can just set the keygroup to latch mode
KenNickels
Apparently the latch mode is only for slice oscillators. I'm using an ircam granular. My workaround is to record one MIDI note, then edit the note-off to be a whole lot of bars later. I thought riding the gain on the osc. would do it. I even deleted the amp.env - it's still (or something still is) gating the osc. Unless I'm doing something wrong.
hugy
Post by hugy »
KenNickels wrote:Apparently the latch mode is only for slice oscillators. I'm using an ircam granular. My workaround is to record one MIDI note, then edit the note-off to be a whole lot of bars later. I thought riding the gain on the osc. would do it. I even deleted the amp.env - it's still (or something still is) gating the osc. Unless I'm doing something wrong.
Latch mode is not only for the slice oscillator. It's just directly in the main parameters in this case.
Check the parameters of the keygroup in the TreeView.
KenNickels
Found it. thanks!
