LAConvolver problem with DP7.24
Bygat
Post by Bygat »
Hi guys!
yesterday i've decided to use LAconvolver for IR with Lepou amp sim, so i copied the .component file of LA 0.3.2 into Library/Audio/Plug In and started DP.
When i put LA into the inert of the aux tracks i created from the sends of the audio track with Lecto , to load some IR , well it doesn't open itself....i don't know why, i have a Macbook Pro late 2011, OSX 10.7.3 , DP7.24...
What can i do to use this plug in?
barreltone
Re: LAConvolver problem with DP7.24
Post by barreltone »
First, check the input/output settings of your aux track. I've noticed plugins on inserts of my aux tracks not loading when the track is not set up properly first.
Hope this helps!
Mac Pro 8 core Nehalem,OS X 10.6.8, MOTU 896HD, DP 7.24, Finale 2009, MSI, Izotope Trash, Spectron, Ozone 4, Alloy, Rx2
Bygat
Post by Bygat »
Well, it tries to open but i can sede only a little blank white square on my Mac monitor...
For my routing: from the sends of the Lepou (with no output) track 2 busses to 2 aux tracks with output my main output..
I'm also trying to have more sends on every track but i ' m not able to manage this task..
Forgive me, i'm newbie!!
Track enabled/disabled?
Bygat
Post by Bygat »
Yes, tracks are enabled.
Klaus
Post by Klaus »
I think I mailed Tobias about this...
I then went and used an older version... of 3.
Best
Klaus
Klaus
Post by Klaus »
Just checked
I use 0.3.1
Klaus
Bygat
Post by Bygat »
Well, now i will look for 0.3.1 and check if it works...
Meanwhile...thanx for the suggestion!
Bygat
Post by Bygat »
Ok , installed 0.3.1 still did not works...
