I've been looking all over Google/MOTUnation for this, but the question is too closely related to the device's sample rate. What I want to know is, at what sample rate is the DSP running effects? Can the resulting audio that comes out of the DSP chip, be it a signal with reverb/comp/eq/ or all three, really have a sample rate up to 192kHz? Or is it something like 48kHz upscaled and mixed back in with the dry signal? (For reference, the Presonus StudioLive mixers run and record at 48kHz, most likely because of the DSP's limitations.)
It's mostly out of curiosity that I ask. Just bought this interface and it should arrive in about 5 days
I'm guessing the effects will sound great through a PA, just curious as to how crystal clear the audio really is fidelity-wise. Could the audio from the DSP be as bit-clear as audio from a similar reverb/comp/eq plugin in a DAW? Or just good enough for tracking and live use? (I don't care for the claims of the DSP audio being of record-able quality, just hunting for an unpublished spec),
-Anup
