Hi Marfin,marfin wrote:Hello,
I'm experiencing the same problems with my Microbook as Bongaloo. Can't get audio from itunes and it won't work with Logic. It is selected if system prefs. and Audio MIDI Setup in Utilities but it still doesn't work. I'm getting sound into Cuemix but not out of it. Has anyone solved this problem yet?
Thanks Marfin
I've tried two different units , and can't find anything wrong with them. I suspect you have a defective unit. I find the Microbook to be the most stable audio interface I've used- it's really impressive at that. Try this (if you haven't) :
You will need to select it in logic (just like all interfaces). for iTunes use, select in audio/MIDI setup...now go to the bottom of that box and click on the 'star' after the '+' and '-' sign to select ' use this device for sound output'
