Importing 3rd Party Sounds Possible?
rank
Post by rank »
Is there a way to import 3rd party sounds? If so...How is this done?
I've read the manual and looked on the forums and web for a while to no avail.
This may seem simple, but obviously it's not for me.
any help much appreciated.
Thanks for reading this.
6 core machine w 24 gigs RAM using Windows 7 - Assorted Plugs/MachFive/UVI packs/Omnisphere/Komplete 7/etc.
Re: Importing 3rd Party Sounds Possible?
Are you talking about samples or programs (patches)?
Also, which version of MachFive?
MachFive 3 makes a big deal about importing 3rd party sound files but states that programs may not load properly.
I have not gotten to that point yet but the promise of that feature set was the main reason I bought it over others.
crduval
Post by crduval »
M5 3 imported all my old K2000/2500 samples without a hitch. If I remember right there was a sequence where I had to install the sample CD, dismiss the Mac unknown format error, then launch M5 after that the sample disk would appear in the browser. From there I think i had to create a disk image inside M5 for the sample CD and it worked fine after that. I'm not in front of the computer so I hope I remember that sequence right!
I think this is covered, although a little thinly, in the manual.
I did have to call tech support once during this process though because I didn't do things in order - if you search the forum I posted the problem and solution.
Good luck!
Chris
M2 MacBook Air, DP11, MOTU MX-4, MOTU Mach5, EWQLSO Platinum, Acoustic Samples B5, UAD Waterfall Organ, EWQL Platinum Pianos, UVI Falcon, UAD-2 Duo, MOTU Ultralite mk5, K2600XS controller
