Bounce to disk problems
jpico
Post by jpico »
When I bounce to disk one of my vocal tracks is getting chopped off at the beggining of a phrase. All other phrases are fine. I tried removing compresros and other effects but to no avail. When I listen to the track in dp the entire phrase is there, but mysteriously it gets chopped when I bounce.
has anyone encountered this? If so any ideas as to how to get around this problem? :?
malditoyanki
Re: Bounce to disk problems
Post by malditoyanki »
Stop bouncing to disk and print a stereo mix inside your session? :idea:
Intel 6core 3.33 Ghz Westmere 48 gigs ram, MOTU micro lite, OS 10.9, DP 8.06, Apogee Symphony I/O, PLAY, most WAVES v9 plugs, Slate plugins, Soundtoys, ProTools 10, Kontakt 5, Omni, Stylus, Ivory
"DON'T fail me again, Admiral..."
Armageddon
Post by Armageddon »
Bear in mind, BTD will only bounce what you select, which is why I usually make sure I select three or four bars past the ending of an entire mix just to get all of my reverb/delay trails. Is it possible you're not selecting the entire "clipped' phrase before bouncing?
Also, I've encountered this phenomenon before, not sure why DP does it. All it usually took was for me to re-bounce the mix (it seemed like it was a random thing) and make sure it had printed properly that time. In my case, it seemed to be a processing glitch. The worst case scenario, I quit DP, restarted my computer and reloaded the project.
malditoyanki wrote:Stop bouncing to disk and print a stereo mix inside your session? :idea:
I know more and more people who work this way. I have pretty good luck bouncing to disk, but considering that I have a UAD-2 plug in almost every project I'm limited to real time bounce so I might as well listen as it goes down I guess. :)
malditoyanki
You're gonna love printing for that reason and others. I've been on many dub stages/ mixing rooms and have NEVER seen an engineer bounce...they always print to a 5.1 or stereo mix inside the session.
jpico
Post by jpico »
Thanks guys. ill try these things and see what happens. 8)
kurtl
Post by kurtl »
This discussion caused me to try a null test. I found a short punk song from one of the bands I record, and first bounced to disk. Then ported everything to an unused bus and printed to disk in real time. I use UAD-1 plugs and MOTU plugs of all kinds. Both of these test tracks started from 0, and went to the end of all soundbites. On playback, with the original tracks muted of course, it was twice as loud so I lowered to -6. Then I selected the print track and "reversed phase" with the MOTU plug. On playback, not a sound at all. I turned my system all the way up, just hiss. I then lowered one of the tracks to -6.1. I got a little audio. I was always wondering about this and this post got me to experiment. It seems like, on my system, printing or bouncing you get the same result. Feel free to do this for yourself and test your system.
DP 11.33, OSX 10.13.6, MacPro 5.1 12 core, 48gigs RAM, 2408Mk3, 2408Mk2, 2 Fastlanes, 2-UAD2 solos, Machfive 2/3.2.1, MSI, BFD3
