How do I make a White Nose Sweep?
Despite using DP for years and years I've never needed to trigger MIDI events. I'm trying to create a "Trance" white noise sweep using PolySynth.
I have a 16 bar sustained note triggeing a white noise patch on PolySynth. Using the Sequence view I inserted Filter Rez markers using the pencil tool. I'm now getting no sound when the track is played back.
Please help!
Thanks,
Yavn
Please help!
Thanks,
Yavn
Re: How do I make a White Nose Sweep?
You'll want to sweep the filter cutoff, not the resonance. You can set the resonance where you want it, you can automate it too (which will control the amount of "whistle" in your sweep). But what you really want to do the actual sweep is the filter cut-off. Of course, you will need the MIDI note to sound the noise in the first place (but you know that).
hahaha. Use a hankerchief.
Computer/s: OSX 10.8.3
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
DAW:DP8.05
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
DAW:DP8.05
VI's/Plug-ins:
million others.
- donreynolds
Ha ha, I did not think you meant your "nose" But I think you can sweep a white nose just the same as any other color. sorry, could'nt resist
Mac Studio M2 OS 15.3 Sequioa, Presonus Faderport 8, 150gig Raptor x 2, Glyph 2Tb drive DP 11.33, Antelope Discrete 8, BLA microclock ll, Presonus Central Station, Waves Plat. V7 , Slate Everything, Melodyne studio, SSD 5, TruePianos, Event 20/20 bas, Adam A7, Avantone Active MixCube, and other toys, Lotsa guitars, HeadRush GTR processor and a Korg Triton)
Re: How do I make a White Noise Sweep?
Darn you spell check!
Actually I figured it out...did not have automation set to play.
Ok - Off to make a patch that sounds good. Anyone have good recomendations to a plugin they love?
Yavn
Yavn
I was gonna recommend suntan lotion.
- doodles
loads of white noise patched in omnisphere.
use modwheel to control speed of rise
