I am posting a newbie question here (mainly because I am a newbie). I did some searches before starting this thread so please just point my nose in the right direction if the issue has been covered here.
I have to make stereo recordings on location and I have the following gear:
Stereo mic setup, Audient Mico, UltraLite mk3, MacBook Pro 6,2.
SW: DP 7.24, MacOS 10.7.3
I used to connect Mico with coax S/PDIF to UltraLite and use Mico's clock as a master. This all could be selected in DP and the setup worked like a charm.
However, I would like to remove UltraLite from the equasion when recording live concerts on-location. I connected Mico's optical S/PDIF output directly to MBP. I then created an aggregate device in Mac Audio/MIDI setup app, using digital input as a clock source:
When I did this, the setup app automaticly selected "drift" checkbox for Built-in output. This resulted in a digital noise. When I deselected "drift", I started to hear occasional clicks when playing back test recording in DP. The clicks appeared randomly so the recording itself seems not to be affected but of course I am not 100% sure that it cannot happen while I am recording 1 hour at a live concert.
The first big question is:
"What does the "drift" option exactly do in Apple Audio/MIDI setup app's Aggregate Device setup?
Apple, weirdly enough, does not provide any useful info on the topic. The drift checkbox has just been left out from the help. What exactly happens if drift is selected on input or output or none or both devices?
The most important thing I want to acheive is:
to get a recording without clicks, using Mico's clock (it appears to be much better) and not having digital noise coming from clock issues in the file.
I will do all necessary cutting and editin later, using UltraLite at home, all I care about is undistorted material on HD.
