UA Neve 88R Plug in crashing DP**RESOLVED**(I think)
I've been having some instability in DP for quite awhile, through several updates. Recently I got to the point of DP crashing as soon as I pressed Play after opening a particular project. After spending lots of time on the phone with a very nice tech support person at DP (Nicole...Thanks!), it was narrowed down to the UA Neve 88R plug in. Disabling this plug in DP Preferences solved the problem. Unfortunately, I love this plugin : (
Has anyone else encountered this, and if so, is there a fix? (Couldn't get UA tech support on the phone)
http://www.thunderingsky.com" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Thundering Sky Recording
South Berwick, Maine
Set-up: DP 7.24, Mac Pro Dual Core 2.66, 22 Gigs RAM, OS 10.6.8, UA 2192 primary converter and Master Clock, MOTU HD 192, Aurora 16, SPL Mixdream, UAD-2 Duo, UAD-Quad, Ivory, Altiverb, PSP, ADD, Sound Soap Pro, Live, Toast, ProTools 9, Omnisphere,
Works well here as well, do you have the latest UAD version?
If not I'd install & see if that fixes.
Have you tried trashing AU components?
UAD tech support via a phone call is great if this isn't working, you probably should call them tomorrow
Re: UA Neve 88R Plug in crashing DP
I use that one all the time with no problems whatsoever. Wish I could help, I wouldn't want to be without that plug in.
Thanks for the replies.
I completely uninstalled all UAD plugs and re-installed latest versions. No change.
Not sure if I trashed AU components, though. I will try that. Is that easy to locate?
Thanks again,
Chris
Thanks again,
Chris
- rodger1811
I hate to sound like a broken record but it works fine for me as well.
Mid 2012 Mac Pro 12 Core 2.4GHz, 24G RAM, OSX 10.8.2, DP 8.01
4x2 TB Hard Drives
APOGEE Symphony
MOTU 2408 mk3
MOTU HD192/Black Lion Modified
MOTU 24I/Ox2
MOTU MIDI Timepiece
Universal Audio UAD-2 Quad x 2
Universal Audio (Entire Plugin Library)
Waves Mercury+ Studio Classics
Tons of other goodies; to many to mention here
4x2 TB Hard Drives
APOGEE Symphony
MOTU 2408 mk3
MOTU 24I/Ox2
MOTU MIDI Timepiece
Re: UA Neve 88R Plug in crashing DP **RESOLVED**(I Think)
I think UA Tech Support has solved my problem. The issue got weirder as the "problem plug-in" mysteriously switched from the Neve 88Rs to the EMT 140. Tech Support had me change a few settings on the UA Console, which makes things a little less responsive, but much more stable (no crashes so far). They felt there must be a DSP bottleneck occurring somewhere. I have 22 gigs of ram, a Duo and a Quad UAD card, and this is not a huge mix, so it doesn't seem like this should be happening......but what do I know?
Anyway, good for now!
As always, thanks for the support.
Chris
Chris
Good news!
The consistent level of 1st rate tech support by UAD for me is what I wish other companies would aim for,imo they are among the best with support.
