Where are templates stored in Lion?
javierdh
Post by javierdh »
Where are the templates stored in Lion? I can't find the [home folder] .
J
NazRat
Re: Where are templates stored in Lion?
Post by NazRat »
They're stored in your user library ~/Library/Preferences/Digital Performer/Document Templates
Your user library is hidden in Lion by default. If you hold the option key while clicking Go in the Finder menu, it will be available for selection. If you want to unhide it, search the internet and a bunch of stuff will be returned.
DP8.06 PT11.2.0 VEP 5.3.x
javierdh
Post by javierdh »
And there they are!
J
Google Lion Library or similar and you will find a terminal command to permanently make the Library visible. Or download Lion Tweaks and use that. Then you won't have to go in via the back door every time you need to get into the Library.
Quick way to show the user library in Lion:
Open Terminal then paste the command below after the prompt; press enter(don't forget to exit terminal)
chflags nohidden ~/Library/
Your User Library folder will now be visible. This keeps it visible - even after reboot.
frankf
Post by frankf »
Once you find it, you can also drag it into the Finder sidebar, but I like the Terminal suggestion in tandem.
Frank Ferrucci
http://www.ferruccimusic.com
javierdh
Post by javierdh »
Thanks to all
J
bluejbill
Post by bluejbill »
Hi, I have made my users Library appear and found the templates folder, but it doesn't seem to contain all of the templates on my list. Including the ones that come with DP.
Is it possible that there is an additional list stored elsewhere?
I want to get rid of a few outdated templates.
2009 2x 2.26 Quad Core Xeon
2408 Mk. III
2408 Mk. II
1224
DP8, Komplete, Ivory, Trillian, Stylus, Omnisphere, East/West Play Orchestra & Pianos, Slate SSD4, EZ Drummer, DMG Compassion & Equality, Wavearts, PSP Delays
Yamaha DM2000
NazRat
Post by NazRat »
The DP8 stuff is at ~/Library/Preferences/com.motu.DigitalPerformer and com.motu.MotuAudioSystem.
bluejbill
Post by bluejbill »
NazRat wrote:The DP8 stuff is at ~/Library/Preferences/com.motu.DigitalPerformer and com.motu.MotuAudioSystem.
Thanks ! Found 'em. But the stock DP templates (16 tracks etc) aren't in there. Are they not removable?
2408 Mk. III
2408 Mk. II
1224
Yamaha DM2000
NazRat
Post by NazRat »
For DP8 those are in /Library/Application Support/MOTU/Digital Performer/Document Templates - that's the local library, not the user lib.
bluejbill
Post by bluejbill »
NazRat wrote:For DP8 those are in /Library/Application Support/MOTU/Digital Performer/Document Templates - that's the local library, not the user lib.
Thanks! Kinda odd that there are two places for document templates!
2408 Mk. III
2408 Mk. II
1224
Yamaha DM2000
Timeline
Post by Timeline »
Shortcut to user Library in 10.8.2
From the finder window hold the option key and "GO". The user Library will appear in the list. This may have been stated earlier as I have not read the entire thread.
