Machfive3 and Protools 10
I purchased MachFive3 2 weeks ago and it works as stand alone application. I am a Protools 10 user (novice) with a Digi #003. I cannot get the MachFive3 plug-in to show up when I try to bring it up as a plug-in as an instrument track. The other RTAS instrument plug-ins show up AND the MachFive3 plug-in IS in the correct location (Library/Application Support/Digidesign/Plug-Ins). What do I do? What am I doing wrong?
Re: Machfive3 and Protools 10
Could it be that you are running in 64 bit?
http://www.steinberg.net/forum/viewtopi ... 19&t=14103" onclick="window.open(this.href);return false;
That's the best info I could find that might help.
Protools is 32bits only so I don't think it's related.
try with 3.0.2 update maybe ?
PT is 32 bit? Go MOTU!!
I have the MachFive3 running the latest update 3.02 and it is running in 64 bit.
Check that you're creating stereo instrument track.
M5v3 do not support mono bus.
Hmmmm....Ill try that. I bet you are right!
Jinkys! All I had to do was make a stereo track and it worked! Thanks!
How does M5 3.1 run in PT10?
