I'm used to twiddling knobs, pushing faders and arming rec tracks...
My old band and i were using Cool Edit Pro breifly before this and recorded some great material that i now want to transfer to my new mac.
My problem with loading the wav files is that the info (position in track) attached to each CEP track will not go with it so i end up with all tracks bunched up together at the 0 (start) line of Logic Platinum 6.
So ideally i need to run the tracks from CEP through the firewire output and into Logic Platinum 6 via the MOTU.
Is this possible/correct?
Is there some way of routing the tracks (ie. Track 1 CEP to Track 1 of Logic) or is it automatic?
Do i need to go through the MOTU at all?
All info on this subject is much appreciated,
Thank you all for your time,
Rorysound.
