labman wrote:BUt.... if it seems like it aint doing anything when you drag it in - dont taunt it and go clicking on stuff. Just wait til the dust clears.
Good advice for a lot of things, throughout DP, throughout life.
Shoosh
Indeed.Shooshie wrote:Good advice for a lot of things, throughout DP, throughout life.
Marc7777 wrote:I started using my new template, and, as usual, ran into a few issues.
Basically my load times are varying. On a fresh template it only takes about 20-25 seconds to load the template: 2 instances of VEP - 1 local, 1 slaved. about 20 Event plugs. maybe 100 MIDI tracks and 50 audio tracks. For sure not the biggest template.
But sometimes it takes a minute for some reason. Then others it's in between.
It seems that if I load a few plugs and start working one day, then come back to it later, it sometimes takes like 2 minutes to load!! .. this isn't cool.. I basically stare at a beach ball for 2 mins wondering if it crashed. then it loads.
What are your experiences?
I have a friend with pretty much the same setup, and he has a pretty big template and his DP projects open in 10-13 seconds! EVERY TIME! ... i'm sensing something is astray here..![]()
~M
We all get to the point where accepting things the way they are is necessary. I think we talked about this in another thread, but VSL used to take as many minutes to load as you guys are speaking of in seconds, being 15-20+. It took a long time for it to get to this point, but 20 seconds for large template for me is brilliant.Marc7777 wrote:
But how do YOU (Shooshie and others) troubleshoot that type of thing? I mean I know the usual troubleshooting technique is to start from scratch and rebuild from there, but what are the more effective ways to go about this? As in, what can I eliminate (if any) that would be the biggest possible culprit? Plugins? RAM? etc. ..from your experience of course. (i know there are lots of variables.)
FWIW, I set up both VEP 32 and 64 bit server to run as startup items. Then they're always running when I need them. You can run both which is THE WAY that I know of to mix 32 and 64 bit plugs. Otherwise, I just create an instrument track with VEP like any other instrument track, it opens a kind of chooser panel with a selector, 32 or 64 bit. Choose the bitness and enter the host name where you want to run the instrument, generally this is localhost if you just have one machine. Click connect and you get a new blank instance window. Configure as desired. Having only just upgraded from VEP 4 to 5 today, I typically only put one multi-instrument in VEP, like a Kontakt, Omnisphere, or some such thing. Each server instance hosts one multi-instrument. (Or I put Ivory II in its own server instance - 32bit pig that it is).Marc7777 wrote:Back on Topic! - VEP on a single Mac. Setup is EASY!! These are the steps I took that gave me the best results (after installation of course):
1) Open DP, but don't load a project. (previously there were issues in the order of starting apps, so i got into the habit of this.)
2) start up VEP Server (32 or 64 bit)
Actually all you have to do after DP crashes, is right-click on the instance that is still connected and it'll say "Force disconnect instance" click that, it'll tell you that it may crash your DAW ... but your DAW is already crashed.. soooo... haSixStringGeek wrote:Biggest headache is DP crashes tend to leave instances around marked as "connected in use" and you need to clean those out now and then, generally by closing DP, then clobbering the two server processes and restarting them.
something I clipped from somewhere...Marc7777 wrote:
The thread usage options in VEP are very flexible, however, the manual (and VEP techs) can't really say what is best to do. What are your experiences?
Marc
I've found that doesn't work 100% of the time in v4, they don't die. Just got v5 so hope this works better.Marc7777 wrote:Actually all you have to do after DP crashes, is right-click on the instance that is still connected and it'll say "Force disconnect instance" click that, it'll tell you that it may crash your DAW ... but your DAW is already crashed.. soooo... ha
