This is the second time I've had to trash Ivory Grand II and reinstall. I keep Ivory II on a Firewire drive and if I open a project that has Ivory II instances and the HD isn't on, DP freezes and quits. So I turn on drive and restart and the Ivory windows come up but the library is empty. Tried turning restarting, etc.. but Ivory can't find library.
This happened before and I had to reinstall. The problem is it takes forever to reinstall Ivory's 11 DVDs.... I thought I remember there being some issue library installer but couldn't remember. I have to finish this cue tonight so I opted for the sure fire reinstall. Curious if any others have dealt with this issue before with IVory or Ivory II??
Ivory II - DP7... Common issue?
Mac Pro 3.2, 8 Core. Mac Book Pro 2.4 GHz Intel Core 2 Duo. Power Mac G5 Dual 2.0. (2) MOTU 2408 MK3's (BLA Mods) & 8 Pre. Motu Micro lite for MIDI (interface for Mac Pro) MOTU Ultralite MK3, Dp 7.2, Reason 4, Ethno 2, MX4, Symphonic Instrument, Mach 5 V2, Electric Keys, Ivory II Grand, Arturia CS-80V, Arturia Prophet V.2, PSP Vintage Warmer, Softube Trident A-Range EQ, IK Classik Reverb, Focusrite Liquid Mix, Peak LE
Affordable "E" Drum session work: gongbass@msn.com
Re: Ivory II - DP7... Common issue?
Never happened to me, and hope it doesn't, as you say it takes forever to reinstall it.
iMac 2.93 Ghz, 12G/Ram, Lion 10.7.2, DP 7.24, Superior 2.3, Ivory II, FM8, NI Vintage Organs, Kontakt, Arturia MMV 2.6, GSI VB3, Samplemodeling, Fractal Axe FX II, Roland A-80, Oberheim Matrix 12, Minimoog, Oberheim 4 voice, etc etc.
- waterstrum
I've never had that happen, but I have Ivory II on an internal drive.
I would contact their tech support.
I'm fairly sure you shouldn't have to reinstall the whole library.
The files are still there, Ivory just can't find them.
Probably a simply fix.
All is well
