buzzsmith wrote:
Thanks...yes, the H-EQ is pretty self-explanatory. It's just the sophistication of the L3 and the C6 that I'm trying to wrap my head around.
I'm gonna try to find some time today, to do some more experimenting.
For mastering (I know every project is different), would you recommend, in this order on the Master bus...or is this overkill in that I might be duplicating functions?
H-EQ
C6
L3
Inspector XL (just to see what my levels look like)
Buzzy
Hard to say, Buzzy. Depends on what you're comfortable with, and what we're calling "Mastering." If I were mastering for real, and by that I mean with Bob Katz looking over my shoulder and/or his book in my hand, I'd probably use the Linear Phase Multiband (rather than the C-6), and the Linear Phase EQ -- both from the Masters Bundle -- along with the L3. Once I feel like I know these plugins very well, I might go ahead and use them rather than the Masters Bundle. But I'm talking about mastering with precision, where you know exactly how much and where you've changed anything.
But if by Master bus you just mean my Submaster Fader or DP's Master fader, then YES! I think you have an ideal list. In fact, that's precisely what I seem to be replacing everything with on my existing projects. If I can't get it with those three things, then it's probably not doable. Of course, I'm not talking about things like delays, triggers, reverb, and so forth. For the basic sound-shaping, EQing, and limiting, these three plugins are currently my go-to chain, along with the S1 stereo imager, and the occasional Trim plugin for precise, magnified metering.
I don't think it's overkill. Sure, you could do it with DP's Masterworks EQ, Masterworks Compressor, and MW Limiter and/or Leveler. But to get the same sound would require a lot of work, if it's even possible. And I don't think that there's much duplication in that list. Sure, they all overlap a little, but the overlap is incidental and not the core function of each plugin.
Also, if I want a deeply analog sound, I might add Nomad Factory's "Magnetic" plugin, perhaps in place of one of the above if I could get away with it.
By the way… just an aside here; did you notice that in the H-EQ you can EQ the L&R tracks separately? Now that's just freaking cool. I wonder how long before all my tracks are filled up with comb-filtering? Guess I'd better watch out for that. But still, just the ability to do that is so cool. I can EQ with a bias toward the bass on whatever channel it is predominant, while keeping the inevitable mid-range clutter out of the other channel where some of my higher instruments may predominate.
Or I could create a 1962 stereo LP with bass on the left and treble on the right!
