Motu 8pre -> Mixer
galileoslastdays
Motu 8pre -> Mixer
Post by galileoslastdays »
Hello.
I'd like to take advantage of the preamps on the 8pre and run them directly into a mixer. Is there a way to split the optical output into respective channels or is there a (rackmount) mixer that will accept these as input and split the channels?
Re: Motu 8pre -> Mixer
There are digital mixers that can process 8 channels of ADAT separately to line outputs.
The MOTU 2408 (all versions) can do this in stand alone mode. An 828, 828mkII or 828mkIII likewise.
Behringer has their ADA8000, a one trick pony designed for this very purpose. $199 street price from most online vendors.
http://www.zzounds.com/item--BEHADA8000" onclick="window.open(this.href);return false;
galileoslastdays
You rock, thank you!
In standalone mode, can I still run the 828mk3 firewire out to a computer?
galileoslastdays wrote:You rock, thank you!
Thanks.
Stand alone mode, by definition, is not connected to the computer :)
OTOH, using CueMix, you should be able to route the signals however you like when connected to the computer.
Here is a link to the available hardware manuals.
http://www.motu.com/techsupport/manuals ... 20download" onclick="window.open(this.href);return false;
