Hello
I have 2 motu 2408 mk3. I use mac pro quad core 3.0 with cubase 6. i connect motus 2408 mk3 with PCIe 424 and with my mackie DXB and i wave serious problems with syncronize.I havent clear sound but with noise.when i sync at PCI 424 internal there is a noise at booth of motu 2408. When I sync one of each other only the synced motu 2408 has clear sound and the other with noise.It fixed for a wile but after became the same again and doesnt change...Please is anyone that knows what happend???
Thank you very much
Spiros
motu 2408 mk3 sync problem
Re: motu 2408 mk3 sync problem
Synced to what? What is the master clock?
hi, i am not discussing any problem but what i am saying, the 2408mk3 is ideal for both the computer-based studio with no mixing board and more elaborate studios built around a digital mixer of any size.
For the computer-based studio, the included PCI-424 card features CueMix DSP™, a flexible DSP-driven mixing and monitoring matrix that eliminates the need for an external mixer or patch-bay. Connect all of your studio gear, including synths, keyboards, and even effects processors. Then control it all from your desktop with no audible monitoring latency and no processor drain on your computer.
With 24 channels of digital I/O, the 2408 is ideal for connecting your computer to a digital mixer. Both ADAT lightpipe and Tascam TDIF digital connections are supported at any sample rate up to 96kHz.
And here’s another 2408mk3 first: built-in video and SMPTE synchronization. Slave your entire workstation directly to video or SMPTE time code with sub-frame accuracy—without a dedicated synchronizer.
The 2408mk3 provides cross-platform compatibility for Mac and Windows with all of your favorite audio software and host-based effects. Or you can use the included AudioDesk workstation software for Mac OS X, with 24-bit recording/editing and 32-bit mixing/processing/mastering.
hello there,m_spiros303 wrote:Hello
Thank you very much
Spiros
I can't believe this: I have nearly the same setup (2 x 2408, cubase 6 and dxb).. only pc instead of mac. I have exactly the same problem. 2nd unit always has pops and clicks. tried different cards (pcix and pcie), different slots. reintalled drivers, different cables. I have reversed units but the second unit in the chain ALWAYS has noise!
I still have not found a solution! But I think it is the drivers!
Thank you very much
Spiros
Spiros
check out this post for a solution to your problem!
http://www.motunation.com/forum/viewtop ... 5&start=45" onclick="window.open(this.href);return false;
