DP and VCC
DP and VCC
Hi
Does anyone experience graphic issue when open VCC MixBuss during playback ?
Same thing in 1.3.5. and 1.5.2 version.
Jovan Haim
Jovan Haim
People will forget what you said, people will forget what you did, but people will never forget how you made them feel !
- Dan Walsh
Re: DP and VCC
What kind of graphic issue?-mine seems to working ok so far.
iMac 3.06 i3|OSX 10.6.8|8 gig ram||DP 7.24|Motu 896HD|2 Avalon VT 737's|Presonus ADL600|Slate VCC|Superior Drummer 2|EZ Drummer|1.1.6|Kontakt Player 4.1|Steven Slate Drums EX|SampleTank 2 XTAntares ATR-1|Presonus Central Station|Neumann TLM 103|Rode NT1|Audio Technica AT 4033 X2| Rode NT-5's|and lot's of other junk
Re: DP and VCC
Sluggy meters on mixing board and on Transport counter slowing down ...
Re: DP and VCC
Re: DP and VCC
Is the VCC actually running in real time? Can't see the CPU meter, it's hidden by the plugin....
How are your buffers set??
It doesn't do this on my current session if I reproduce this scenario, all smooth....
Stephen
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Re: DP and VCC
Yes, in realtime... buffer size 512 ... CPU usage is less then 5% ... just a few tracks and plugins...
Re: DP and VCC
Same tracks and same plugins doesn't have that issue in Logic... just checked it out
Re: DP and VCC
What version of DP are you running? I had issues with DP 7.21 or maybe it was 7.22 with sluggish meters and missing MIDI notes. Try upgrading to 7.24 - it's free - and see if your meter issues go away. Mine certainly did.
Re: DP and VCC
I already have 7.24 ... that sluggish happens only when vcc mixbuss is in the front ... when it's behind everything is normal...
Re: DP and VCC
Sounds like you may want to report this to Slate.
Re: DP and VCC
Already did that... waiting for the answer...
- thethethediamondz
Re: DP and VCC
definitely not for me. i'm using VCC 1.5.2 and DP7.23 on a Mac Pro 2x2.26ghz quad core xeon, 8gb memory.
i know u said that it worked fine in Logic and that the CPU was quite low, but is your oversampling cranked up for real time rendering? i don't oversample at all in real time, only offline.
mac pro intel 8 core, 2.26 GHz,
8GB memory,
Mavericks
DP8.07
828 mkiii, Burl Bomber AD, UAD2, abbey road, voxengo, airwindows, novation nocturn, soundtoys, Akai MPK-88, Ramsa WR-T820
VIs - U-HE Ace, Zebra 2, Bazille
=(^._.^)=
8GB memory,
Mavericks
DP8.07
=(^._.^)=
Re: DP and VCC
Without oversampling...
Re: DP and VCC
Try increasing the buffer pre-load setting.
Re: DP and VCC
No luck ... I notice when click on the plugin and move it on the other side of the monitor, during movement meters on mix-board totaly freeze...
