FW 1884 Dp 7.2
DJ LOKO
FW 1884 Dp 7.2
Post by DJ LOKO »
Hi new to the forums love the site. Have a question does anyone use dp7 with tascam fw 1884. it works great but when you use the faders to mix its jittery when your mixing down a track. would that be a hardware problem or software problem. I have been using the mouse to mix down cause that problem any help
thanks.
Re: FW 1884 Dp 7.2
Jittery sounds like a lag of some sort. Even if it steps through MIDI parameters - lots do without the stutter. I would suspect a priority or driver issue.
Can it use other protocols such as the Mackie? Many such controllers can. You might also check a TASCAM users group to see if there is a workaround.
Gravity Jim
Re: FW 1884 Dp 7.2
Post by Gravity Jim »
These guys are very helpful:
http://tascamforums.com/" onclick="window.open(this.href);return false;
I think this would be your forum:
http://tascamforums.com/index.php?s=cc8 ... owforum=22" onclick="window.open(this.href);return false;
Jim Bordner
