"service battery, battery is charged" message
Nibiru
Post by Nibiru »
Hello all!
In changing some setting in the Energy prefs the other day, I noticed the message, "service battery, battery is charged".  I'm on a March 2008 MBP 2.6.
I did some googling, as ya do, and found some articles/message boards regarding this message.  Some think SL has a bug that makes this message appear, some think SL caused some makes and models of batteries, to over tax the battery, causing it to die prematurely. I have noticed my fans are running more and faster, with not much taxation on the CPU. I've calibrated the battery, which made the message go away for a day. Then it came back. I must admit, I was never in the habit of calibrating my battery thru the years. It's pretty much always been plugged into the power adapter.
Anyone here at the Nation have any experience with this?  Any help is greatly appreciated!
Nibiru
Mac Mini M2 Pro - 16gb RAM - 500gb SSD | Apollo Twin Duo MkII | UAD Satellite x 2 (thunderbolt) | UAD plugins | Dell 2721QS Monitor | PMC Result 6 | DP 11.22 | Ableton | Luna
Re: "service battery, battery is charged" message
When you say "thru the years", how many years? The battery doesn't last forever, even if you don't use. Maybe the message is a roundabout way of saying that it is charged, but still isn't working. Have look at Coconut Battery http://www.coconut-flavour.com/" onclick="window.open(this.href);return false; This will tell you how much power your battery can store at full charge, compared to what it could do when it was new, how many charging cycles it has been through, the current charge level, etc. When the first number drops significantly, Mac OS will start telling you to fix or replace your battery.
IO
Re: Re: "service battery, battery is charged" message
Post by IO »
Nibiru wrote:It's pretty much always been plugged into the power adapter.
Nibiru
Always allow the battery to drain and recharge...
Sent from my Nexus S using Tapatalk
3Ghz 8core Trash Can 64GB RAM OSX 10.13.2 | UAD Apollo 8 Quad | UAD Apollo Twin MKII Solo | DP 9.51 | ProTools 12.8.3 | Studio One 3 | Logic Pro X | DSP Quattro | Waves | UAD
Re: Re:
Nibiru
That's the calibration process, which he already did.
Dan Walsh
Post by Dan Walsh »
I have a 2008 MBP 2.4 The battery turned bad and apparently was a failing common that year. I took it in last year, and they tried to zap the PRAM but it turns out the battery was just toast. The new batteries fro apple are ridiculously overpriced (IMHO) but I bought an after market battery and all is well again.
Hate to say it, but yer battery is probably done.
iMac 3.06 i3|OSX 10.6.8|8 gig ram||DP 7.24|Motu 896HD|2 Avalon VT 737's|Presonus ADL600|Slate VCC|Superior Drummer 2|EZ Drummer|1.1.6|Kontakt Player 4.1|Steven Slate Drums EX|SampleTank 2 XTAntares ATR-1|Presonus Central Station|Neumann TLM 103|Rode NT1|Audio Technica AT 4033 X2| Rode NT-5's|and lot's of other junk
IO
Re: Re: Re:
Post by IO »
bayswater wrote:
Nibiru
Yeah, but this is something that must be done regularly, not like one time. Leaving a laptop connected to a power adapter all the time will damage the battery and shorten its usage life.
mrbillet
Post by mrbillet »
[quote="Dan Walsh"] The new batteries fro apple are ridiculously overpriced (IMHO) but I bought an after market battery and all is well again.
/quote]
Say, where do you get one of these batteries?
-Ian
MacBookPro 1.83GHz Core Duo, 2G RAM.
OSX 10.6.8
DP 5.13
MOTU 828
Tascam cassette 4trk
Nibiru
Post by Nibiru »
Thanks for the replies!
I ended up buying a new battery last night for $130. I'll be following the rules of battery maintenance this time around. Hopefully this will keep my MBP running at normal temps, keeping the fan from coming on so much. Thanks again for everyone's input. I do appreciate it very much!
-Nibiru
Dan Walsh
Re:
Post by Dan Walsh »
-Ian
Sorry Ian--I've been away for a bit.
http://www.canada-battery.ca/laptop-batteries/apple.htm
My battery was around $50.00 and it arrived over night from Vancouver. Not sure how US shipping would work for you, but good luck. I've had the battery for a year and it's workin' fine. The original Apple battery didn't even go a year before the trubs started.
