DP 3.1 "cannot find installer CD" message
woe is me... I got a new (believe it or not) Digital Performer 3 to use with my G4 and MOTU 2408. cool... almost. I also got OS9.2 and I can alternate between OS... when I install something requiring OS9 it automatically goes to classic mode. I was able to install a lot of the things from the CD but when I tried to install DP 3 I get a message saying "Cannot find installer CD".. what's that all about?
Re: DP 3.1 "cannot find installer CD" message
Is it the original MOTU CD you are using? Do you have the key code (back of the manual).
Yes, this is the original... I installed other items from the same CD, following instructions from the CD.. so I don't understand.. I do have the code key, this DP3 came new, right out of the box
- FutureLegends
The CD must be inserted when you authorize DP. You can't install, remove the CD and then run DP. The first time that is...
