Behringer ADA8000 with 828MK3
RapturesPitBull
Post by RapturesPitBull »
Is anyone using the ADA8000's with the 828MK3? I have 2 ADA8000 lightpiped into my 828mk3, the top ADA works perfectly, the lower one gives me a blast of white noise in the right ear then the left ear alternating every 10 secs. I have switched the 2 units I have and it doesnt matter which is on the bottom of the rack I get the same noise. Any Ideas?
NazRat
Re: Behringer ADA8000 with 828MK3
Post by NazRat »
DP8.06 PT11.2.0 VEP 5.3.x
billruys
Post by billruys »
How are you synchronising your ADA8000s with your 828? Are you syncing them with the lightpipe outputs from the 828? Usually bursts of noise are due to synchronisation errors. I usually use the MOTU as the timing master and slave my ADA8000 to it.
RapturesPitBull
OK how is the best way to do that?
