How to Freeze audio in MONO
anthonie
Post by anthonie »
Hello,
I want to freeze a mono miditrack form a plugin...let say Modulo 12.
I create an aux track and set the input to Modulo12 AUX 1 in mono.
Now....when I freeze the track , it will create a stereo track; which I don't want.
I can't fugure how to freeze to mono (1 audio file).
Anyone knows??
thx regards Tom
MOTU 896 HD, Powermac G5 QUAD, 2.5 Gb RAM, 1 Tb HD's, NI Kore, Novation Remote SL 25, M-audio Trigger Finger, GEM S2 Master Keyboard, Mackie Line-Mixer. Technics Sl 1200.
DAW's: MOTU DP5.1, Logic Express, Cubase SX3
Pluggies/Software instr.: NI, Spectrasonics, Korg, Arturia, Waves, Native Bundle, Audio Ease etcetra...
Dan Worley
Re: How to Freeze audio in MONO
Post by Dan Worley »
That is odd how it switches to a stereo buss when freezing, even if you have the track output to a mono bus. And when the track is output to a mono bus, I just noticed that it will come out as a mono track when the freeze is complete but the soundbite will be empty. Very odd.
I would just bounce it mono and have it added to the sequence. It's like 20 times faster anyway. Disable or delete the original track when you're done.
c-ya,
Dan Worley
DP10.13
anthonie
Post by anthonie »
so that means i have to set the main out to mono and then freeze, then add to the track and set the main outs to stereo again?????
that will work, but a little bit strange indeed
Dan Worley
anthonie wrote:so that means i have to set the main out to mono and then freeze, then add to the track and set the main outs to stereo again?????
Modulo is stereo only, as far as I know. Set it to output on buss 1-2 (or whatever buss will isolate it) and bounce it, but choose Mono (with 3.5 dB attenuation) and select to have it added to the sequence. When that track is created set its output to the mains.
No freezing is involved.
c-ya,
Dan Worley
DP10.13
anthonie
Post by anthonie »
thx man!
