Firepod with OSX Lion?
vigormusic
Post by vigormusic »
Has anyone happened to try the Presouns Firepod with OSX Lion yet? Curious to if it'll work.
Kev
2.8 GHz Intel Core 2 Duo Macbook Pro(Late 2008), 8GB RAM, Mavericks, Presonus Firepod, DP 8.05, EWQLSO, SSD4.
Re: Firepod with OSX Lion?
Presonus is saying that nothing is 10.7 compatible - yet. Historically, they are always pretty far behind when it comes to new drivers - ok, not as far behind as ProTools...
jmadill
Post by jmadill »
Actually, I think you may it to be compatible. If you look at Presonus's web site, it says "No driver required" as did my FireBox, which works fine.
Can't say the same for my FireStudio Lightpipe ... :-(
-jm
vigormusic
I've used my firepod for the past 4 Mac OS's, never installed a driver.
Using Lion, I just fired up Digital Performer 6(which MOTU said wouldn't work) through my firepod(which presonus said wouldn't work) and laid down some vocals. Everything was fine!
DP 5.13 & 6.03 work fine on my machine. I don't believe that you can install them on Lion, however, as the installers are PPC - also authenticating the installer CD doesn't work. But upgrading a working copy on a 10.6.8 drive does work.
