Very helpful!
SirJo
I always do while on stage. It takes light significantly lower.bolla wrote:If you are bored with the Motu themes.....
Control/Option/Command/8
will reverse the spectrum of your monitor.Cheers, Bolla
How do you "de bug"via the console please?daveswallace wrote:please add a note about debugging via the console to the optimization section! An old MIDI driver was forcing my audio/MIDI server to restart in 32 bit mode, causing all sorts of issues with DP, including horrible performance. It even crashed all my convolution reverbs.
I ran through all the optimization, and it helped a little, but this was the main culprit.
Since Snow Leopard, this started happening to me intermittently (booting in 32bit mode) about once a month. I will get my computer started load my DP project and sit down to work, and discover that there is no MIDI being transmitted from external controllers, even though the project will play previously recorded MIDI. The only solution is to reboot the computer.Shooshie wrote:I have to boot Audio-MIDI Setup in 32bit mode, or it won't work. Suddenly there will be no connection from external MIDI to DP or anything else. So, I go to the app itself, get info, then select "always boot in 32 bit mode" on the Info window. Log out, and log-in again. Then things finally work fine.
It's very good of you to have taken this on. Do appreciate your efforts.Shooshie wrote:....it's a little more up to date, though there is a long way to go. I still have a backlog of dozens of tips that need to be added, even though I went ahead and added some that were posted just a few days ago.
I do not often get time to work on this, so thanks for being patient. I figure I'll get it all up to date, then DP8 will come out and look entirely different, and I'll have to start again!
Ha! We're still a long ways away from needing dogs to tell apart the Terminators from the real humans...keiranval wrote:Digital Performer is a full-featured Digital Audio Workstation/Sequencer software package published by Mark of the Unicorn (MOTU) of Cambridge, Massachusetts for the Apple Macintosh platform.
Groth was an employee of MOTU from 1984 through 1989, being the force behind the creation of the original Performer, from version 1.0 through version 2.3. The Performer you see in this flier was apparently Roy's work.David Mash, of Berklee wrote:We were using computers in the curriculum back in late 1982, with the Apple II, so when the Macintosh came out, we were probably one of the first music schools to jump on the bandwagon and see its value. One of my students was involved with writing the first sequencer program for the Macintosh– his name was Roy Groth and he worked at Mark of the Unicorn [www.motu.com] developing a program called Performer, which is now called Digital Performer.
Groth went on to bigger jobs and larger paychecks when Digital Performer was just getting started, leaving us with a huge blank space from 1989 through 2001, during which we know very little about who worked on DP. At least, *I* know very little. Maybe someone else can fill in some history. I knew about people in the other departments, for I talked to them periodically, or communicated by mail. Those included people like Danny Rose, Jim Cooper, and Les Quindepan, who as far as I know are still with MOTU.John Andrew Parks wrote:Around the same time, I was also involved with some computer geniuses from M.I.T. and they had made me a beta tester for the first music sequencer on a Macintosh. The lyric premise was a work of musical science fiction and fantasy. Nothing like that was going on at the time. 'Planet Texas' was a milestone both musically and technologically. I would work on the song until the program crashed and then Roy Groth, the inventor of the 'Performer' software, would send me the fix over a 300-baud modem. The whole thing was done on a 512k Fat Mac with the use of only floppy disks. It was very exciting on so many levels.
