Anyone get this issue with Nomad Factory plugs?
AnthonyS
Post by AnthonyS »
Hi:
Not sure if this is an actual DP issue, or a Nomad Factory one, but if you insert a Nomad Factory plug on an aux, the GUI doesn't display unless you specify an input. Doesn't happen on a Master, or if you use on an insert. None of my other plugs do this.
So I'm not sure if this a real issue or not, since the plug needs something sent to it anyway, right? Just maybe the way NF sets up their plugs.
Just wondering if anyone else had ever noticed it...
MacBook Pro 15" 2G QuadCore i7,8G RAM, 20"Intel iMac 2.4Ghz , 4G RAM.OSX 10.8.3 on both, DP 7.24, MOTU 828MK3, AudioBox 1818, KRK Rokit 6G2, Omnisphere 1.5, Komplete 8, Amplitube 2&3, SampleTank, Sonik Synth2, SampleMoog, SampleTron, Ivory 2, Philharmonik, EWQL MOR, SC, SOG, SD2, Reason 6, Waves, McDSP, Slate Digital VCC, FGX, Sound Toys.
buzzsmith
Post by buzzsmith »
I think Waves, etc. is the same. if the plug (on an auxiliary track, like for reverb) is not assigned an input it doesn't display until an input is assigned.
I'll double check later.
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
AnthonyS
Re: Anyone get this issue with Nomad Factory plugs?
Post by AnthonyS »
Buzzy, I just confirmed that Waves plugs do this as well.... I thought at first something was wrong with my authorizations, but it just must be the way they behave.
Post by Shooshie »
A Master Track only has an output. It's not configurable as a routing tool like an Aux track. Audio tracks that already contain audio don't need an input, but can use one optionally.
An aux track, however, is not a track until it has an input AND an output. It's just a routing device, and until it has something to route, it's theoretically just a place-holder.
thethethediamondz
Post by thethethediamondz »
i've had this problem and it's driven me crazy. not with Nomad, but with UAD, i think.
i'd see the plug's name but i couldn't open it to mess with the settings. then other instances of the plug would be working fine.
haha. it's really good to find out exactly why this was happening, i've seriously spent hours tearing out my hair about it. i've always fixed it, but i guess by accident everytime.
thanks for this post!
mac pro intel 8 core, 2.26 GHz,
8GB memory,
Mavericks
DP8.07
828 mkiii, Burl Bomber AD, UAD2, abbey road, voxengo, airwindows, novation nocturn, soundtoys, Akai MPK-88, Ramsa WR-T820
VIs - U-HE Ace, Zebra 2, Bazille
=(^._.^)=
Radiogal
Post by Radiogal »
As far as I can remember this has always been like that.
No AUX input no GUI...
I never considered this to be a "problem" as one always needs to assign an input on the AUX track to make it work anyway.
AnthonyS
Post by AnthonyS »
Yeah, probably not really a "problem", just caught me off guard. Hadn't noticed it before, so i wasn't sure if there was something wrong. But it does makes sense when you think about it...
