Can't install Waves Kramer MPX on 10.6.7 (10.5.8 OK)
- spitfire31
Hi,
I'm tearing my hair and am about ready to give up.
I bought the Waves MPX tape emu plug-in and it installs just fine on my MB Pro 2,2 running 10.5.8.
But, on my new MB Pro 17" early 2011, running 10.6.7, the WOLI_V8.app downloader/installer just won't launch.
I get the Admin password dialog, type my password and hit OK. The same dialog comes back, I repeat the above actions, the menu bar shows "Waves Complete V9r7 Web Installer" for a few seconds and then – nothing, back to Finder.
Repairing permissions and rebooting makes no difference. I had the same problem with the DP 7.2.3 installer and on a fellow Motunationer's advice, I created a new account and managed to run the DP installer. No such luck with the Waves installer. It did launch the first time, but the resulting installation was useless in my admin account. The next time I tried with the new account, the installer wouldn't launch. Starting up in Safe mode makes no difference.
Since my 17" MB Pro is now my main audio workstation, it seems that I paid a 100 buck to Waves for nothing. And Waves support hasn't replied after one week…
I guess there's a pref or something somewhere preventing the installer to launch properly. Any informed ideas would be more than welcome!
Best,
Joachim
Best,
Joachim
If it were easy, anybody could do it.
Re: Can't install Waves Kramer MPX on 10.6.7 (10.5.8 OK)
Do you have Rosetta installed?
Some Universal Binary applications still use a PPC installer. If that is the case, the app should work in 10.6.x but it won't install unless Rosetta is present.
Just a guess.
Just a guess.
- spitfire31
Thanks for the hint! However, if Rosetta were necessary – why did the installer work once (only) in a freshly created new account?
Anyway, I'll install Rosetta anyway as a sacrifice to the Snow Leopard Baron Samedi.
/Joachim
/Joachim
I think you are correct it is a permissions issue,I installed it last week in 10.67.I had a problem with Ilok, I could not get the Mac to see the ilok using Firefox and Chrome after several attempts I decided to try Safari and got it running.
At 1 point I called Waves tech support ,they seem to have pretty good support via the phone have you tried calling them?
Good Luck
KG
Good Luck
KG
- spitfire31
Thanks! However, in my case it's not an iLok issue – my license is downloaded on my tiny little iLok 2 without problems, once I read the warning on ilok.com that it doesn't support Firefox 4.0 yet. They have to hurry, since the Firefox 5.0 beta is out…kgdrum wrote:I think you are correct it is a permissions issue,I installed it last week in 10.67.I had a problem with Ilok, I could not get the Mac to see the ilok using Firefox and Chrome after several attempts I decided to try Safari and got it running.
Good Luck
KG
/Joachim
- spitfire31
Belatedly, I checked the logs and found that the Waves installer, WOLI_V8.app, just crashes.
If anyone can get some ideas from the crash log, I'm all ears.
/Joachim
Process: WOLI_V8 [6470]
Path: /Users/joachimsmith/Desktop/WOLI_V8.app/Contents/MacOS/WOLI_V8
Identifier: WOLI_V8
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: WOLI_V8 [6466]
Date/Time: 2011-06-28 22:00:11.210 +0200
OS Version: Mac OS X 10.6.7 (10J4138)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 com.apple.CoreFoundation 0x97119933 CFBooleanGetValue + 83
1 com.apple.HIToolbox 0x94916d5d GetCurrentInputSourceKeyboardProperties + 176
2 com.apple.HIToolbox 0x949163df TSMTranslateKeyEvent + 74
3 com.apple.HIToolbox 0x9491618b TSMKeyTranslateWithInputSource + 609
4 com.apple.HIToolbox 0x94915f0f TSMKeyTranslate + 106
5 com.apple.HIToolbox 0x94915e1e TranslateKeyToUniChar + 65
6 com.apple.HIToolbox 0x94915da5 KeyEventSetDerivedData + 83
7 com.apple.HIToolbox 0x94915c4e KeyEventMatchesUniCharAndModifiers + 89
8 com.apple.HIToolbox 0x94915b01 LoadHotKeyInfo(KeyFocusKey, unsigned int) + 176
9 com.apple.HIToolbox 0x94915802 SyncWithKeyPrefs() + 309
10 com.apple.HIToolbox 0x9492015a _GetSymbolicHotKeyValue2 + 282
11 com.apple.HIToolbox 0x9491ff76 InitHelpKeyData(HelpKeyData*) + 82
12 com.apple.HIToolbox 0x9491fe97 SuppressMenuCommandKeys(MenuData*, unsigned char) + 33
13 com.apple.HIToolbox 0x9491f53b _CalcMenuSizeOnDevice(MenuData*, unsigned short, unsigned int, CGRect const*, unsigned long) + 543
14 com.apple.HIToolbox 0x94ac97e1 CalcMenuSize + 61
15 com.apple.HIToolbox 0x94a0176c HIPopupButton::GetMenuWidthSmartRecalc(OpaqueMenuRef*) + 30
16 com.apple.HIToolbox 0x94a019e7 HIPopupButton::GetOptimalSizeInternal(CGSize*, float*) + 619
17 com.apple.HIToolbox 0x94a03b3b HIPopupButton::LayoutIfNecessary() + 97
18 com.apple.HIToolbox 0x94a03f30 HIPopupButton::DoCalc(OpaqueRgnHandle*, __HIShape const**) + 20
19 com.apple.HIToolbox 0x94a0420e HIPopupButton::GetPartRegionOrShapeSelf(short, OpaqueRgnHandle*, __HIShape const**) + 278
20 com.apple.HIToolbox 0x948eb2e3 HIView::SendGetPartRegionOrShape(short, OpaqueRgnHandle*, __HIShape const**) + 247
21 com.apple.HIToolbox 0x9499ac6a HIView::CopyPartRegion(short, OpaqueRgnHandle**) + 112
22 com.apple.HIToolbox 0x949b03f6 HIView::RecursiveDrawNonComposited(short, OpaqueGrafPtr*, OpaqueRgnHandle*, unsigned char, unsigned char, unsigned char) + 398
23 com.apple.HIToolbox 0x949b0741 HIView::DrawNonComposited(short, OpaqueGrafPtr*, OpaqueRgnHandle*, unsigned long) + 293
24 com.apple.HIToolbox 0x948f448c HIView::Draw(short, OpaqueGrafPtr*, unsigned long) + 154
25 com.apple.HIToolbox 0x948e56f4 HIView::Show(unsigned char) + 352
26 com.apple.HIToolbox 0x949a05a1 SetControlVisibility + 80
27 com.apple.HIToolbox 0x949a8b61 NewControl + 4773
28 com.MindVision.VISEX 0x00012652 InitGlobals + 5812
29 com.MindVision.VISEX 0x000131fd main + 81
30 com.MindVision.VISEX 0x00001a72 _start + 216
31 com.MindVision.VISEX 0x00001999 start + 41
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x904bf942 kevent + 10
1 libSystem.B.dylib 0x904c005c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x904bf519 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x904bf2be _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x904bed41 _pthread_wqthread + 390
5 libSystem.B.dylib 0x904beb86 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x9049911a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x904c6ca1 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x904f5ac8 pthread_cond_timedwait_relative_np + 47
3 ...ple.CoreServices.CarbonCore 0x97ac0d9d TSWaitOnConditionTimedRelative + 242
4 ...ple.CoreServices.CarbonCore 0x97ac0adb TSWaitOnSemaphoreCommon + 511
5 ...ple.CoreServices.CarbonCore 0x97ac0771 AsyncFileThread(void*) + 102
6 libSystem.B.dylib 0x904c6819 _pthread_start + 345
7 libSystem.B.dylib 0x904c669e thread_start + 34
Thread 3:
0 libSystem.B.dylib 0x904cbdf9 syscall + 5
1 com.apple.OpenTransport 0x16e7f987 CarbonSelectThreadFunc + 257
2 libSystem.B.dylib 0x904c6819 _pthread_start + 345
3 libSystem.B.dylib 0x904c669e thread_start + 34
Thread 4:
0 libSystem.B.dylib 0x904c7062 __semwait_signal + 10
1 libSystem.B.dylib 0x904c6d1e _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x904c89b8 pthread_cond_wait$UNIX2003 + 73
3 com.apple.OpenTransport 0x16e7bec7 CarbonOperationThreadFunc + 203
4 libSystem.B.dylib 0x904c6819 _pthread_start + 345
5 libSystem.B.dylib 0x904c669e thread_start + 34
Thread 5:
0 libSystem.B.dylib 0x904be9d2 __workq_kernreturn + 10
1 libSystem.B.dylib 0x904bef68 _pthread_wqthread + 941
2 libSystem.B.dylib 0x904beb86 start_wqthread + 30
Thread 6:
0 libSystem.B.dylib 0x904990ba mach_msg_trap + 10
1 libSystem.B.dylib 0x90499827 mach_msg + 68
2 com.apple.CoreFoundation 0x9711437f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x97113464 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x97113291 CFRunLoopRunInMode + 97
5 com.apple.Foundation 0x97fe56d0 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
6 com.apple.Foundation 0x97facaac -[NSThread main] + 45
7 com.apple.Foundation 0x97faca5c __NSThread__main__ + 1499
8 libSystem.B.dylib 0x904c6819 _pthread_start + 345
9 libSystem.B.dylib 0x904c669e thread_start + 34
Thread 7: com.apple.CFSocket.private
0 libSystem.B.dylib 0x904b8086 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x97153c83 __CFSocketManager + 1091
Thread 8:
5 ...ickTimeComponents.component 0x98cbf205 ReadSchedulerThreadEntryPoint + 4698
Thread 9:
5 ...ple.CoreServices.CarbonCore 0x97b1b692 AIOFileThread(void*) + 1127
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x971198ec ecx: 0x00000000 edx: 0x00000015
edi: 0x003368e0 esi: 0x00000000 ebp: 0xbfffebd8 esp: 0xbfffebc0
ss: 0x00000023 efl: 0x00010283 eip: 0x97119933 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000000
Binary Images:
0x1000 - 0x7dfe7 +com.MindVision.VISEX 4.0 (4.0) <34A9E6AB-72DA-3F9C-BF89-97FFBD8320BB> /Users/joachimsmith/Desktop/WOLI_V8.app/Contents/MacOS/WOLI_V8
0x12493000 - 0x12495ff7 com.apple.PDFImporter 2.1 (???) <23C79166-0DE3-C646-FD0A-99FF84AB55FF> /System/Library/Components/PDFImporter.component/Contents/MacOS/PDFImporter
0x12713000 - 0x12716fef com.apple.LiveType.component 2.1.3 (2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x1271b000 - 0x12780fde com.apple.LiveType.framework 2.1.3 (2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x127a0000 - 0x127e6fc3 com.apple.motion.component 1.0 (1.0) <77973A13-4E79-426F-853F-2318E52A2207> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x127ec000 - 0x127ef02f Motion ??? (???) <B5E862EE-E0FF-4F86-A789-98E3E601A18C> /Library/Frameworks/Motion.framework/Versions/A/Motion
0x127f9000 - 0x127faff7 +com.WavesAudio.Version_Match_Plugin ??? (1.0b1) <F388D9C0-3FA0-DB38-FD45-C938C8E99B59> /Users/joachimsmith/Desktop/WOLI_V8.app/Contents/PlugIns/Version_Match_Plugin.bundle/Contents/MacOS/Version_Match_Plugin
0x16e79000 - 0x16e93ff7 com.apple.OpenTransport 10.6.0 (10.6.0) <9571BE66-BDE4-7499-FF79-C3D63D3776E2> /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <283EE026-C0FE-1FF9-DB81-BFB155793157> /usr/lib/dyld
0x90051000 - 0x900fbfe7 com.apple.CFNetwork 454.11.12 (454.11.12) <F637DBD0-CA3F-F536-6ABF-FA8B16A44DBA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x900fc000 - 0x9012dff7 libGLImage.dylib ??? (???) <314E14A3-AA04-0586-20D2-F0209B8BDF1C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x901fe000 - 0x902defe7 com.apple.vImage 4.1 (4.1) <AEF800AE-65DA-5E79-5B01-165AF51BAAF6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x902df000 - 0x9038dff3 com.apple.ink.framework 1.3.3 (107) <E215794C-F3E9-C067-8882-9054796DDA8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x90498000 - 0x9063fff7 libSystem.B.dylib 125.2.10 (compatibility 1.0.0) <E9242C9C-0EE8-0658-F002-D05DA4164F0F> /usr/lib/libSystem.B.dylib
0x90640000 - 0x90a75ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <4D2F47EF-BD32-1E3C-6A0A-438896ADE2BE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x90af4000 - 0x90b16fef com.apple.DirectoryService.Framework 3.6 (621.11) <401E67B3-96DF-287B-2892-210C3A2EE9A6> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x90b17000 - 0x90b17ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x90b18000 - 0x90b28ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <E276514D-394B-2FDD-6264-07A444AA6A4E> /usr/lib/libsasl2.2.dylib
0x90b29000 - 0x90c03ffb com.apple.DesktopServices 1.5.10 (1.5.10) <CF69F8CA-DC47-EF8E-AD79-04D589B7D116> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x90c56000 - 0x90d84fe7 com.apple.CoreData 102.1 (251) <0C2636F3-CCB4-5ED9-1D3E-5AE36BE57071> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x90e6a000 - 0x90ea7ff7 com.apple.SystemConfiguration 1.10.5 (1.10.2) <EFC2E4A9-B905-5B37-3E1A-13FCC1D7B9B4> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x90ea8000 - 0x90eacff7 IOSurface ??? (???) <7D8204CE-3FF9-27EC-A760-9321C44467A2> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x90f1c000 - 0x90fd2ffb libFontParser.dylib ??? (???) <D85C1840-0FA8-27A2-54B7-FF336099EBC0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x90fd3000 - 0x91083fe3 com.apple.QuickTimeImporters.component 7.6.6 (1772) <0756403D-6CE7-5715-4182-DA167D45A1F7> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x91143000 - 0x911d5fe7 com.apple.print.framework.PrintCore 6.3 (312.7) <EE9ED7BE-7D97-B759-C063-1E4B7DBD3775> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91200000 - 0x9187bff7 com.apple.CoreAUC 6.11.01 (6.11.01) <A8B4E7FE-6BB8-8B07-1607-EA1AC0516ECE> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x9187c000 - 0x9206b557 com.apple.CoreGraphics 1.545.0 (???) <2E0455F5-A2DC-4AC2-B19A-3335FD8A2B1D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9206c000 - 0x92079ff7 com.apple.NetFS 3.2.2 (3.2.2) <0A53CD10-DBC7-2BE8-34F7-354BE201F6FB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x9207a000 - 0x9209eff7 libJPEG.dylib ??? (???) <B54ACF14-A32D-C90D-D086-5CE54CFC29B5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9209f000 - 0x920a2ff7 libCoreVMClient.dylib ??? (???) <E5E756D0-FC65-227B-DC92-10874062FF5D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x920a3000 - 0x920e9ff7 libauto.dylib ??? (???) <7CB1AB76-50A2-8E56-66E4-CF51CA75B177> /usr/lib/libauto.dylib
0x920eb000 - 0x921b6fef com.apple.CoreServices.OSServices 359 (359) <1EBCB6E1-C23A-D21A-0FDE-B3763DCCF790> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x921b7000 - 0x921ddffb com.apple.DictionaryServices 1.1.2 (1.1.2) <5A8D5D84-06EB-F9B5-BA0A-A87A0A2C0035> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x921de000 - 0x9222eff7 com.apple.framework.familycontrols 2.0.2 (2020) <592738FA-B093-279A-8D4E-3F76A21E2912> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x9222f000 - 0x92299fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x92596000 - 0x9259cfff com.apple.CommonPanels 1.2.4 (91) <CE92759E-865E-8A3B-1488-ECD497E4074D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x9259d000 - 0x925d6ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <A618C135-8463-B2C4-C3E5-16DD58E0E389> /usr/lib/libcups.2.dylib
0x925d7000 - 0x925dbff7 libGFXShared.dylib ??? (???) <8498CFA9-E0A3-7A74-FCF6-EC23E1C07083> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x927e4000 - 0x92817ff7 com.apple.AE 496.4 (496.4) <23F0DB1F-2856-0091-80AE-BDEF9A4F1731> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x92818000 - 0x9281dff7 com.apple.OpenDirectory 10.6 (10.6) <7E8AFE74-1FA9-7B35-A0E3-545959A9CA73> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9281e000 - 0x92862ff3 com.apple.coreui 2 (114) <1A3C3B7F-3837-6477-3114-47F6BFD56CB2> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x92a46000 - 0x92a46ff7 com.apple.Cocoa 6.6 (???) <5A785062-1ABB-2A54-BAAC-8FEF95275E05> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x92a47000 - 0x92a6fff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <12FBE8CB-CC8E-FE8A-7362-C852625C5AAF> /usr/lib/libxslt.1.dylib
0x92b4e000 - 0x92b89feb libFontRegistry.dylib ??? (???) <D7E411FC-E649-ED9E-8D16-E70C4410157C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x92cec000 - 0x92cf3ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <46BD2265-78DC-2FAB-73C6-E224755C070D> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x92cf4000 - 0x92df5fe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <E1A44C67-FA6C-0188-F46F-EA14CEE557BB> /usr/lib/libxml2.2.dylib
0x92df6000 - 0x92dffff7 com.apple.DiskArbitration 2.3.1 (2.3.1) <AAE0185D-4A47-1833-27A3-03FDF734A3BA> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x92e00000 - 0x92fbafeb com.apple.ImageIO.framework 3.0.4 (3.0.4) <40F9474B-8819-CDF7-A4E2-8963E723ED8C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x92fbb000 - 0x92fbcff7 com.apple.audio.units.AudioUnit 1.6.6 (1.6.6) <E49F6AB1-941E-5DA8-575F-D816A449624B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x92ff5000 - 0x92ff6ff7 com.apple.TrustEvaluationAgent 1.1 (1) <06484720-AB50-6FD9-B5BF-05F5A640C9E5> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x93010000 - 0x93010ff7 com.apple.CoreServices 44 (44) <B9461120-F72A-D28F-D0CF-5647958BD3F9> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x93011000 - 0x93011ff7 com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x930b4000 - 0x930b7ff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <2EF58C9C-AA19-BC68-8C94-449DE9237288> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x930b8000 - 0x930fbff7 libGLU.dylib ??? (???) <0CF0BB97-62AA-6A63-7FF9-F06E4F42176C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9314d000 - 0x931cdfeb com.apple.SearchKit 1.3.0 (1.3.0) <7AE32A31-2B8E-E271-C03A-7A0F7BAFC85C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9323d000 - 0x935a8ff7 com.apple.QuartzCore 1.6.3 (227.36) <7844CA24-7A00-EB86-9631-0461DE4FF46E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x936fa000 - 0x9370efe7 libbsm.0.dylib ??? (???) <B328FA0A-899C-4FC4-F2AC-2FDC08819CD2> /usr/lib/libbsm.0.dylib
0x9370f000 - 0x93711ff7 com.apple.securityhi 4.0 (36638) <A5F4B929-AEDE-2DFB-E02F-89CEC0940023> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9371a000 - 0x9371aff7 com.apple.Carbon 150 (152) <8DD4F8DB-6DBD-1F65-F4EB-2981DBFDED50> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x93904000 - 0x93948fe7 com.apple.Metadata 10.6.3 (507.15) <C318F4FA-E7F7-8C59-1CD3-FC3EDAAEC223> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x939c5000 - 0x939cffe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <DE0E0EF6-8190-3F65-6BDD-5AC9D8A025D6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x939fc000 - 0x93a10ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <9F5CE4F7-D05C-8C14-4B76-E43D07A8A680> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x948c3000 - 0x948c6ffb com.apple.help 1.3.1 (41) <6A5AD406-9D8E-5BAC-51E1-E09AB9A6D159> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x948c7000 - 0x94bebfef com.apple.HIToolbox 1.6.5 (???) <F21289A3-A00E-0BC3-66F1-7557862CE7EB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x94bff000 - 0x94cacfe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <F237B77D-75A3-7240-931D-4735B91D365F> /usr/lib/libobjc.A.dylib
0x94cad000 - 0x94cc2fff com.apple.ImageCapture 6.0.2 (6.0.2) <88A621FB-8462-2010-22A5-55D2848E4CB3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x94cc3000 - 0x94ce3fe7 libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <584B2B30-DC65-6930-F59F-C49FD5604B67> /usr/lib/libresolv.9.dylib
0x94ce4000 - 0x94d27ff7 com.apple.NavigationServices 3.5.4 (182) <FE19D51B-233A-69EC-9E36-B89D0EA438C1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x94e91000 - 0x94eb0ff7 com.apple.CoreVideo 1.6.2 (45.6) <F9E52A13-E181-D302-3B0E-0799ED6D6130> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94eb1000 - 0x94eb7fe7 com.apple.CommerceCore 1.0 (9) <DC6B8176-5526-581F-A977-5A6D20FDAA09> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x94ef8000 - 0x94f49ff7 com.apple.HIServices 1.8.2 (???) <BBE23110-368B-EE45-9D1D-D61473BF2078> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x951a2000 - 0x95203fe7 com.apple.CoreText 3.151.8 (???) <940ECF78-8BC2-B74E-F815-FDFFB3C550C2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x952eb000 - 0x95393ffb com.apple.QD 3.36 (???) <5A93B258-3853-636F-DB26-223642DA2779> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x95394000 - 0x95c74ff7 com.apple.AppKit 6.6.7 (1038.35) <8070FE1F-1B86-F58C-441F-FF8629F5061D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x96172000 - 0x9622bfe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <03186216-0A12-4AA9-D7BA-3E3551A1195C> /usr/lib/libsqlite3.dylib
0x9622c000 - 0x96408fe7 libType1Scaler.dylib ??? (???) <CB930F73-3CD3-BF41-645B-470660F57FF6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x96409000 - 0x9642afe7 com.apple.opencl 12.3.6 (12.3.6) <B774CF2D-C067-DFFE-3EE6-90A036E36E06> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x9642e000 - 0x96431fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x968be000 - 0x968c2ff7 libGIF.dylib ??? (???) <24DF7EB7-913B-DF67-C98E-63A987359A16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x968e3000 - 0x9699ffff com.apple.ColorSync 4.6.6 (4.6.6) <8FB2E63C-FA84-1CFD-15ED-F9FEC7A019A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x969b4000 - 0x96a01feb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <9E35835E-BC33-F8EC-8F3B-84D51DEBDB16> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x96a02000 - 0x96a9afe7 edu.mit.Kerberos 6.5.11 (6.5.11) <88CA2CC8-9005-E017-6D61-5809C3CE5FC6> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x96a9b000 - 0x96aa5ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <90C38107-AEE7-AE55-5C51-28D129B19BCD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x96ab6000 - 0x96ab6ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x96ab7000 - 0x96abeff3 com.apple.print.framework.Print 6.1 (237.1) <726A7F31-8C27-8403-0016-71E022EDC14C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x96abf000 - 0x96b5aff7 com.apple.ApplicationServices.ATS 275.15.1 (???) <6AFD74A0-3A75-1362-E1EC-FC85EE3F68B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x96b5b000 - 0x96ba4fe7 libTIFF.dylib ??? (???) <883E22E0-2D17-14F4-0B7D-69025BA7EFD8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x96ba5000 - 0x96bc1fe3 com.apple.openscripting 1.3.1 (???) <0E6B81D1-C1BD-1B5F-836F-256E6701B5DE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x96c6c000 - 0x96c87ff7 libPng.dylib ??? (???) <ED4DF104-C0A1-6614-7CEE-DA0937196DD3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x96c88000 - 0x96d8cfe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.
<C2C11723-A56D-C790-4E4D-BE6C82CC1099> /usr/lib/libcrypto.0.9.8.dylib
0x96d8d000 - 0x96d9bff7 com.apple.opengl 1.6.13 (1.6.13) <3E7B0FAC-B5DF-A87F-CD3F-2A053B033155> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x96e53000 - 0x96f5fff7 libGLProgrammability.dylib ??? (???) <D8A31B5B-26F7-7AB6-F4F4-D720384947E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x96f60000 - 0x96fc4fff com.apple.htmlrendering 72 (1.1.4) <0D22B190-513B-7FF6-39FC-9D336285DE08> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x96fc5000 - 0x9703ffff com.apple.audio.CoreAudio 3.2.6 (3.2.6) <FCE540B8-6AF3-E309-2650-E1D835C2771E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x970d7000 - 0x97252fe7 com.apple.CoreFoundation 6.6.4 (550.42) <BA29C5CE-77DB-87DB-5B74-9EEFF5265681> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x97253000 - 0x97253ff7 com.apple.ApplicationServices 38 (38) <EAF1BC8C-4FD4-4300-B8F7-4B24E49125E2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9743a000 - 0x97448fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <E1B922F4-23DC-467E-631F-7E1B9C9F51CB> /usr/lib/libz.1.dylib
0x97481000 - 0x97897ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <9D89FCB3-24C9-8FCF-DB49-27B184AC3222> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x97898000 - 0x97907ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <B3DEACA1-9375-CF8F-0898-AA2C5F8159DC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x97a7a000 - 0x97d9aff3 com.apple.CoreServices.CarbonCore 861.34 (861.34) <88A96F0F-C8A6-BB10-70AE-B9C30E15EEAA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x97d9b000 - 0x97d9bff7 liblangid.dylib ??? (???) <FCC37057-CDD7-2AF1-21AF-52A06C4048FF> /usr/lib/liblangid.dylib
0x97d9c000 - 0x97db4ff7 com.apple.CFOpenDirectory 10.6 (10.6) <6D726EA4-67D2-E534-13A3-E3767BA59786> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x97ebf000 - 0x97ecbff7 libkxld.dylib ??? (???) <4088783A-C805-4191-0E77-4D949B48F49D> /usr/lib/system/libkxld.dylib
0x97f51000 - 0x97f53ff7 libRadiance.dylib ??? (???) <F333B039-FF8D-6CE1-C758-213523EFF928> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x97f54000 - 0x97f95ff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <D05D8E9E-8FBF-CAA0-6FBF-2FD960A9F943> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x97f96000 - 0x98209fe7 com.apple.Foundation 6.6.6 (751.53) <CBEA97E4-811D-CBCF-63A0-B43D5C45A90D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9820a000 - 0x98346ff7 com.apple.audio.toolbox.AudioToolbox 1.6.6 (1.6.6) <F4E5167C-E184-8D2D-082B-0B3EB751F707> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x98385000 - 0x9867efef com.apple.QuickTime 7.6.6 (1772) <9ADC7B34-ED10-9F8F-EC52-22DA2417DFBB> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9867f000 - 0x9868aff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <DE92F56A-7F89-FEAD-CE94-324C4BF7C487> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9868b000 - 0x986beff3 libTrueTypeScaler.dylib ??? (???) <E5E16584-870F-CBCD-F861-3BB45324DE16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x986bf000 - 0x986d0ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <B59157A1-8796-CE8F-2508-EB96F093F6A7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x98707000 - 0x9965afe3 com.apple.QuickTimeComponents.component 7.6.6 (1772) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x9965b000 - 0x996b8ff7 com.apple.framework.IOKit 2.0 (???) <4389DF74-E070-C787-4EC1-7754B5AE19B3> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x996b9000 - 0x9983bfe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <3F00D378-803C-5011-6A29-4461F06AFD44> /usr/lib/libicucore.A.dylib
0x9985f000 - 0x998e1ffb SecurityFoundation ??? (???) <20512B7E-DC54-8242-B656-64DCA1BFB739> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x99964000 - 0x9996fff7 libGL.dylib ??? (???) <4425B9AA-B494-A336-EABB-6BBC9FF4EC4F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x99970000 - 0x999b2ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <1AE34B00-8A62-1E51-935F-BB3F0E4BE50F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x99a28000 - 0x99ac5fe3 com.apple.LaunchServices 362.2 (362.2) <16E9C194-A145-5BD0-2A8B-8E610AE1169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x99bdc000 - 0x99e41feb com.apple.security 6.1.2 (55002) <7F00A51B-F22A-0EBC-A321-923472D686BD> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x99f49000 - 0x99f5bff7 com.apple.MultitouchSupport.framework 207.11 (207.11) <08850988-36D7-D2D8-D407-75EBFC811A1C> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <E9242C9C-0EE8-0658-F002-D05DA4164F0F> /usr/lib/libSystem.B.dylib
/Joachim
Identifier: WOLI_V8
Version: ??? (???)
Report Version: 6
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 8:
Thread 9:
cr2: 0x00000000
Binary Images:
- KEVORKIAN
I installed MPX on 10.6.7 a few weeks ago with no issue.
Have you tried downloading the latest Waves WOLI again? Maybe you just have a corrupted download of the WOLI?
- spitfire31
Yes, and no respectively…KEVORKIAN wrote:Have you tried downloading the latest Waves WOLI again? Maybe you just have a corrupted download of the WOLI?
Now I'm finally in contact with Waves web support; I hope that a solution will come. In the meantime, I'm receptive to good ideas, though!
/Joachim
