MP3 to Aiff
MP3 to Aiff
Looking for an audio application to convert several folders of mp3 files to aiff in a single batch process and not just one at a time.
Recommendations please.
Mac OS: Mojave
Re: MP3 to Aiff
QuickTime Pro could do that. I haven't tried QuickTime 10 to see if it can do more than one at a time.
Re: MP3 to Aiff
I was just looking at Barbabatch
http://www.audioease.com/Pages/BarbaBatch/" onclick="window.open(this.href);return false;
But it's quite expensive, so.....................
............. try opening a new DP session, set it to AIFF and drag all the MP3s into DP's soundbites window. Let DP do it's thing, and that should be that, the session will have an Audio files folder with all the converted files.
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Re: MP3 to Aiff
http://www.macupdate.com/app/mac/18278/qtamateur" onclick="window.open(this.href);return false;
DOn't be fooled, it ain't just for video. Batch convert works fine on MP3 to AIFF.
This program is the best kept secret on the Mac!
Re: MP3 to Aiff
Open batch export, drag your files into that window, do your settings, and off you go.
Works great in every kind of conversion, including resizing a video. Use it all the time.
MP3 to Aiff
Oh, and it's free.
Re: MP3 to Aiff
Terrific!! Thanks!!
Stephen
Stephen
Re: MP3 to Aiff
I have Amadeus Pro, and their batch functionality works great.
Just had a thought...could you do this in DP? In a new project, drag/drop your mp3 files to the SB window or even onto the SE. I think as long as your prefs were set to the right file format (and interleaved), and to import audio into your Audio Files folder, you'd have a folder of all your converted mp3s in that Audio Files folder.
Matt
Matt
Mac Pro 8 core Nehalem,OS X 10.6.8, MOTU 896HD, DP 7.24, Finale 2009, MSI, Izotope Trash, Spectron, Ozone 4, Alloy, Rx2
Re: MP3 to Aiff
Thanks to one and all for the excellent recommendations and heads up instructions.
Used DP7 for this job and it is sooo simple and effective. Therefore no need to buy Barbabatch at this time.
Tried Amadeus Pro but
could not figure it out and did not have the time to plow thru the instructions or head to their forum.
Thanks again.
Thanks again.
Mac OS: Mojave
- Dwetmaster
Re: MP3 to Aiff
For those that have it, audiofinder is great for this too.
There is also a program called "Max"http://sbooth.org/Max/
works great but haven't been updated in a while so can be buggy at time. But it's free.
Re: MP3 to Aiff
Glad DP worked for you - I thought it would! And about Amadeus - yes it seems easy to me now, but it didn't seem the most intuitive to me when I first learned the function. So I get what you were saying there.midiw wrote:Used DP7 for this job and it is sooo simple and effective. Therefore no need to buy Barbabatch at this time.
Tried Amadeus Pro butcould not figure it out and did not have the time to plow thru the instructions or head to their forum.
Re: MP3 to Aiff
barreltone
Just discovered that Amadeus Pro version 2 ( recently released ) has a huge fix for this type of job whereby you can actually drop a file or folder to a designated box and it works.
ifully understand that developers have to make some money but for me the upgrade price is not realistic. Although having said that since i have an open wallet for software purchases no doubt i will upgrade and pay the $$$$.
Mac OS: Mojave
Re: MP3 to Aiff
CAN YOU HEAR ME NOW!
You don't need to spend a penny for batch export.
MIDI Life Crisis wrote:http://www.macupdate.com/app/mac/18278/qtamateur
Don't be fooled, it ain't just for video. Batch convert works fine on MP3 to AIFF.
Re: MP3 to Aiff
Do you have Amadeus already, and would get in for the upgrade to 2.0? If you have the Pro version, 1.x, then that batch function is already there. If you have Amadeus II (not pro), then you're right, it's a big upgrade. I'm not pulling the trigger on it over here yet, and the dev is getting some complaints about the upgrade price over at MacUpdate.midiw wrote:barreltone
Re: MP3 to Aiff
He was able to take care of this in DP, so he doesn't really need that program either.MIDI Life Crisis wrote: You don't need to spend a penny for batch export.
Thanks for mentioning it again, though. I'll take a look at it myself!
