I use windows7 64bit.
MOTU 896 sound card is the old version.
I installed the latest drivers. (MOTU_Audio_Installer-Win-100920)
But he can not work in windows7 64bit.
What solutions can solve this problem?
Thank you!
MOTU 896 & windows7 64bit question?
Re: MOTU 896 & windows7 64bit question?
It could be a Firewire issue or trying installing an older version of the drivers. If you solve your problem, please, let me know. I have the same problem that you.
MOTU 896 MK3.
DAW: Cubase 5.5.2
PC laptop: Win7 64bit + intel core i7 720 1,66Ghz + 8GB RAM + NVIDIA® GeForce® GT 335M 1 GB DDR3.
Firewire ExpressCard: Sweex FW022 (chipset VIA)
DAW: Cubase 5.5.2
Dont feel alone
1 more with similar problem.
If I find out any solution Ill post here also...
Share if you find also.
Regards!!!
Regards!!!
I found out a solution....
Try this guys, maybe it helps
http://www.motunation.com/forum/viewtop ... 14&t=46734" onclick="window.open(this.href);return false;
cya
cya
