hello guys,
i will try to explain my problem ..
i am using in every tracks at least one long and big Lexicon pcm reverb.
So for example i am working on the track and listening a sound in the reverb.
Then if i am returning at the beginnning of the track the reverb is still working and i have to wait that the reverb stop working before i can record something. If not i will have the sound of the reverb of another sound in that recording.
To resume is it possible to make a reverb stop working when u press stop and go back to the beginning of the track in DP ?
thanks if u can help..sorry for the bad explanation..
Question about DP ...
Re: Question about DP ...
Are you running the instances of the verb in pre-gen mode or in real-time?
Mac Pro 8 core Nehalem,OS X 10.6.8, MOTU 896HD, DP 7.24, Finale 2009, MSI, Izotope Trash, Spectron, Ozone 4, Alloy, Rx2
If I understand your message correctly, you don't need to place the reverb in every track if it is the same reverb. Create a master fader and insert one instance of the plug there. Running in real time will solve your problem (as above).
Yes i was in pre-gen mode, i am now in real time and i am not having the problem anymore. Thanks for the help guys!
