Audio MIDI Setup doesn't remember arrangement...RESOLVED
Re: Audio MIDI Setup doesn't remember arrangement of devices
Hey Guys,
Sorry for the problems. I believe this is an issue only with the 64-bit version of Audio MIDI Setup. As a workaround, select the Audio MIDI Setup application icon and do a "Get Info". Then select the checkbox corresponding with "Run in 32-bit Mode". This should fix your issue.
Hope this helps,
Michael
Hope this helps,
Michael
Thanks for the suggestion, Michael! Not at the studio now but can't wait to try this.
- daniel.sneed
Thanks Echopoint.
Great tip!
My AMS is back, clean and tidy, at last.
And this one has been puzzling me for long.
Great tip!
dAn Shakin' all over!
Re: Audio MIDI Setup doesn't remember arrangement...RESOLVED
WOW!! Finally tried this too. It worked! Hooray! Thanks!
- Shooshie
Wow! What a great one to remember.
I'm still in the mode of avoiding 64bit wherever possible. It has caused me nothing but grief.
Yeah, but you know what... I didn't even know that option existed. When I moved over from my G5 to my Mac Pro with SL this started happening. 64-bit was enabled by default it seems. Wish I'd know what was causing this sooner!amplidood wrote:I'm still in the mode of avoiding 64bit wherever possible. It has caused me nothing but grief.
- daniel.sneed
Echopoint, this appear to be your first post on this board.
And such a great tip. I'm stumped.
Well, hum... your'e welcome!
- mhschmieder
Thanks so much for this tip -- I implemented the suggestion, and it appears that this solves my AMS problem that I thought would go away (but didn't) when I started from scratch with a new Intel MacPro last November.
I'll know for sure when I boot up my home computer tonight after work, but a couple of launches last night seemed to indicate that AMS is now tidy!
Just looked for it on my G5. Not there.James Steele wrote:Yeah, but you know what... I didn't even know that option existed. When I moved over from my G5 to my Mac Pro with SL this started happening. 64-bit was enabled by default it seems. Wish I'd know what was causing this sooner!amplidood wrote:I'm still in the mode of avoiding 64bit wherever possible. It has caused me nothing but grief.
iMac 2.7Ghz quadcore i5 16 gig RAM DP 7.24 OS 10.6.8, iMac G5 2.1GHz 2.5 gig Ram DP 5.13 OS 10.4.11 MOTU 828 MK2, East West Platinum Plus, Miroslav Philharmonic, Komplete 5, Kontakt 2 Garritan Big Band, Mr Sax T, The Trumpet, DrumCore, Trilogy and Trillian, Ivory, MachFive, Ethno Instrument, Reason 4, SampleTank 2 Sampletron, Samplemoog, Melodyne Editor, Nomad plugins, Vintage Warmer, Ozone 4, Amplitube Jimi, Xgear and AmpegSVX.
http:www.davidosuna.com
It wouldn't be. From what I understand you'd have to be running SL on an Intel Mac to see this option.dosuna11 wrote:Just looked for it on my G5. Not there.
Re: Audio MIDI Setup doesn't remember arrangement...NOT RESO
Hello,
For the first time in many years, I have lost my Audio MIDI Setup configuration. I tried searching here and got this thread. I figured I could restore my Audio MIDI Setup from my last Time Machine backup, when everything worked. I tried the solutions in this thread, including finding the AMS file residing in the User/Library/Audio/MIDI configuration folder and restored that from my backup. That did not work. Can anyone hear please tell me how to do this, so I don't have to recreated everything from scratch?
Thanks for any help.
Kinny Landrum
Kinny Landrum
DP 10.11 MacPro 16-core 3.2 GHZ, 48 Gb Ram, 10.15.2, numerous VIs, etc.
