DSP-Quattro and DP?
adriano
DSP-Quattro and DP?
Post by adriano »
Hello forum.
Anyone using DSP Quattro?
I have some VST plugins that can output to MIDI and was wondering if, I was to load the VST plug into DSP-4, if I will be able to output to MIDI into a MIDI track in DP. In other words I would use it is a VST host.
I tried Rax 3.0 from Audiofile Engineering, but does not support MIDI out.
Thank you,
Adriano
iMac9,1, 3.06GHz Intel Core 2 Duo, 8GB-RAM, 10.9.5
DP 8.07, 828MKIII, Keys-Fantom X8, XV-88. Key
SampleTank v2.5.4, Miroslav Philharmonik v1.1.2, SampleMoog v1.02, SampleTron v1.02, Sonik Synth 2 v2.1.1, Independence Pro v3.2.0126, EZDrummer 1.4, MDrummer Large 5.02, Komplete U9, Orchestral Essential 1, Orchestral Essential 2, Complete Orchestral Collection
Music is the wine that fills the cup of silence.
David Polich
Re: DSP-Quattro and DP?
Post by David Polich »
Despite the fact that DSP Quattro can run VST plug-ins, you will
not be able to instantiate DSP Quattro in DP and then load VST
plugs or VI's into it. Sorry...only MAS or AU will run inside
DP.
http://www.davepolich.com
I haven't tried this specifically with DSP, but any application that uses CoreMIDI should be able to access Inter-application MIDI (part of OSX). If you invoke IAC in AudioMIDI Setup, both DSP and DP should see it as a MIDI device and be able to use it as an input or as an output. Might help to Google an IAC tutorial to see how it is done.
cridarco
Post by cridarco »
I use Audio Ease VST-Wrapper and it works fine inside DP.
Performer user since 1991.
adriano
Post by adriano »
cridarco wrote:I use Audio Ease VST-Wrapper and it works fine inside DP.
Ciao Cridarco,
Ho fatto ricerca sul google e apparentemente AudioEase VST wrapper non funziona con Mac Intel.
Qua sta il link:
http://www.audioease.com/cgi-bin/forum/ ... 1262733952" onclick="window.open(this.href);return false;
Grazie
Elio
Post by Elio »
Italian Motunation ?
ciao Adriano,come ti trovi adesso con Independence ?
adriano
Post by adriano »
Ciao Elio, come stai?
E si, Motunation e' pure italiano :) Io sono di Salerno, pero' sono vissuto negli USA da 22 anni. Quando ho finito il militare sono venuto qua.
Mi trovo bene con independence. L'unico problema che c'ho e' che Yellow Tools non responde alle emails. In altre parole, se c'hai domande ho ti serve aiuto, sei solo.
Ciao,
Adriano
Elio
Post by Elio »
hai ragione il supporto di YellowTools è pessimo ma il software è ottimo e francamente non dà molti problemi.Comunque in Italia ad usare DP siamo veramente in pochi.Un saluto da un Siciliano che vive a Bergamo.
adriano
Post by adriano »
Elio wrote:hai ragione il supporto di YellowTools è pessimo ma il software è ottimo e francamente non dà molti problemi.Comunque in Italia ad usare DP siamo veramente in pochi.Un saluto da un Siciliano che vive a Bergamo.
I miei migliori amici sono Siciliani, dal militare e fortunatamente pure qua e non sto scherzando.
Contracambio i saluti da parte mia pure a te dall"America.
Ciao
