Hey guys,
Couple quick (hopefully) questions for all of you smart people out there.
1) I was running XP SP2 and upgraded to SP3 because it's required by Sonar X1 (which apparently I'm the only person on earth to be using, but that's another story). The parallel driver doesn't seem to work any more. Has anyone heard whether there's an issue with SP3?
2) In the unfortunate (and costly) event that I need to move to a MTP-AV USB, can I at least slave one of my Parallel ones to it via RS-422?
3) Any idea whether MOTU might consider releasing the API (or driver source, outright) for the MTP-AV Parallel? I heard mutterings of Linux support, but nothing firm.
I'm 99% sure nothing changed except SP2 (working) to SP3 (broke'd).
Thanks!!
MTP-AV parallel and Windows XP
Re: MTP-AV parallel and Windows XP
hey
I am running xp sp2 as well. I have no experience running
mtp av via parallel connection. I have read that others have had success
running sp2 and sp3 and parallel mtp ax.
I can confirm that the mtp av and mtp av USB can be networked via
rs 422 serial ports in xp.
