828mk2 firewire and windows 7 problem
MaWi
Post by MaWi »
Hi,
my Motu 828mk2 firewire doesn't work with windows7. The installation with Motu Audio Installer Win 110314 was successful, but there's no sound.
And i can't make any changes in the DSP-CueMix . Computer : i7 2600k processor, Gigabyte Motherboard GA PH67A-UD3-B3 and a dawicontrol firewire card with texas instrument chip.
anyone who can help ?
greetings
MaWi
abdiel
Re: 828mk2 firewire and windows 7 problem
Post by abdiel »
Recently went win7 with an ultralite hybrid. USB worked and seemed to with firewire until I actually tried to output sound. Ended up changing the 1394 device driver in device manager to 1394 (legacy) and it fixed it. Hope this helps.
MaWi
Post by MaWi »
Hi Abdiel,
thanks for your reply.I Have changed the driver from 1394 to 1394 (legacy).
Before i Had changed this i had problems to open the cue mix console (all actions with many seconds delay). Now it works normal .So the 1394 legacy driver is a first step in finding a solution. Anyway , i have no sound . And all changes i want to make in the cue mix console are turning back . For example I 'm trying to change the output "none" to "main out 1-2" . After 1 second it returns to "none". I think that i have no access .
greeting, MaWi
abdiel
Post by abdiel »
Well, that might be as far as I can help... Stuff worked fine for me with the legacy driver, but I'm using a mk3, so can't help with cuemix dsp. If it was me, I'd remove the drivers for the motu and reinstall them. Also, it seems like there are firmware updates for some interfaces. If you haven't, maybe do that before reinstalling drivers. That's all I got. Good luck!
