Changing/syncing tempo of loops
How can I sync the tempo of a loop in machfive to sync with the tempo in DP4?
Loop sync
I believe you would be better served putting the loop directly in an
audio track in DP , then use either
Set Soundbite to Seq tempo or Set Seq tempo to Soundbite tempo
Pull the loop into a track... Pull down the "AUDIO" menu and choose set soundbite tempo first, then proceed from there.
HTH
HTH
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
