Just got a 2408 MKII to go with my MKIII and 424 card.
Trying to get the 2 to work together with Sonar at 24 bit.
Sonar seems to not work with the MKII at 24 bit. The MOTU Control
panel only shows the 2408 MKIII and 2408 (not MKII). MOTU Tech support
has been no help...does not respond to Tech requests. Same result if
I try tunning the MKII alone on the 424 card.
Should Sonar allow 24 bit with a MKII? Should the control panel
be reporting a MKII instead of original? Is anyone running a MKII
Thanks, Denny
2408MKII, Sonar and 24 bit?
