Slate Digital VCC Available Now w/ Free iLOK2 This Week Only
cbergm7210
Re: Slate Digital VCC Available Now w/ Free iLOK2 This Week
Post by cbergm7210 »
Killahurts wrote:
jloeb wrote:
Killahurts wrote:Mixing an album now. The CPU hit with this plugin is profound, brings my 12-core to it's knees. The sound is fantastic for sure, but I have to say, I'm very disappointed with the performance otherwise.
I don't know if I can get through my deadline with this, I may have to bail.. :shake:
Just curious: How many tracks? Buffer? Pre-rendering on?
Only 10 stereo tracks and 3 mono tracks on the mix I did this morning. Don't ever have pre-render on, realtime always. My buffer was on 256. I couldn't increase it because on this track I was using outboard FX with the "Latency Fixer" plugin. If I increase the buffer, I would have to go in there and recalibrate the latency of each hardware box (by hand), and I don't have the time today- although I may end up doing that anyway.
Someone told me to check the oversampling setting of the plug, but I can't get to the preferences without crashing.
I would not hesitate to say that increasing the buffer would have a good chance of helping in this case. Just guessing.
http://www.rfjmusic.com
stephentayler
Post by stephentayler »
There is a new update on the Slate website, v1.06, but sorry to report absolutely nothing has changed for me in DP or PT.
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Killahurts
Post by Killahurts »
Killahurts wrote:My buffer was on 256. I couldn't increase it because on this track I was using outboard FX with the "Latency Fixer" plugin. If I increase the buffer, I would have to go in there and recalibrate the latency of each hardware box (by hand), and I don't have the time today- although I may end up doing that anyway.
Well it just occurred to me that this is not necessarily so.. DP should do the math here, right?
If the latency to and from the OB gear is already compensated for, DP should set it all straight, no matter what I set the buffer to.. I think.. :wink:
stephentayler
Has anyone with any DP/OSX configuration got VCC working??
Stephen
Steven Slate
Post by Steven Slate »
Hi Guys.. PM me your ticket numbers.. I'll send them directly to the front of the line. Also.. we just contacted MOTU to try to discuss some things with them and to get the newest DP update.
The new 1.06 should have fixed the CPU issue btw.. please check and post results.
Grigri
Post by Grigri »
Hourra!
I was able to make VCC 1.06 to work on my Macpro :D :D
To cut a long story short, the guilty was the MAS AudioUnit Support.bundle on my Macpro.
I've tryed the VCC on my Macbook Pro and the VCC worked just fine on this machine!! :shock:
After investigation on the MacBook Pro the version of the MAS AudioUnit is: version 1.7.0 (35805)
On my Macpro the version of the MAS AudioUnit is: version 1.7.0 (42086)
If you have the (42086) version, you can download the (35805) version with the link down below and give a try. It may be wise to make a copy of your original MAS AudioUnit before making the swap (I.E. copy it in another folder on the desktop)
Here is the link: http://grigrisound.com/tech/mas_audioun ... _35805.zip" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
I will update my ticket at Slate suport and forum
Cheers :D
Digital Performer 11.31 - Mac OS Sonoma 14.6.1
stephentayler
remove post - sorry
Grigri
Post by Grigri »
Hello Stephen!
The original is located in the Mas folder in the hardrive library.
Here is the path: /Library/Audio/Plug-Ins/MAS/
You should see the MAS AudioUnit Support.bundle in it.
If you "get info" (command - I) on the original, please check what version number do you have.
Let me know if it works
David
stephentayler
Thanks I just figured that out.... will try and get back to you!!
Cheers
Stephen
stephentayler
Good grief!!! How on earth did you figure that one out??
Let's get on to Slate about this.....
to be clear... this sorted out the issue of the blank plugin screen, group setting and the crash on re-opening.....
Thanks SO MUCH!!
let's get this sorted
Stephen
Grigri
Post by Grigri »
Cool!!
stephentayler wrote:How on earth did you figure that one out??
I decided to try VCC on my new MacBook Pro. It have a fresh OSX and DP install. At my big surprise, it worked :shock:
So I start to search differences in the plugins et voila...
There is still the hijack of the transport but that is something not urgent for me.
So far so good, everything is working here, I'm a happy camper 8)
I have posted my result at the Slate forum and I have updated my open ticket plus PM Steven
Cheers
David
stephentayler
OK tests run in DP 7.22 with this replacement MAS AudioUnit Support 1.7.0, (35805)
VCC grouping feature works, plugins close and open without crashing and settings retained on saving project.
I'll say that has me sorted for my current project then...... now I can get excited again.
David, thank you so much.... I've tacked this onto my extensive ticket at Slate...
All the very best
Stephen
Grigri
Post by Grigri »
Stephen, you're welcome! I wish you great success for your project 8)
David
stephentayler
David this is worthy of a new thread... I've been trying to get to the bottom of this since last friday
Cheers
Stephen
stephentayler
I just received my free iLok 2, all the way over here in England. I actually already had one, but it is great to see that Slate have been honourable, and they have also been extremely responsive. Now I have a spare, can't be a bad thing.
I'm already impressed with VCC, but intend to put it thoroughly through its paces next week, and introduce it to the album I have just finished mixing!!
Exciting!
Stephen
