Intermittent Micro Lite problem
Occasionally (like once every 5 times) when I boot my PC my Micro Lite comes up with all inputs lit. I've tried two Micro Lites on the same PC any they both do the same. It's an ASUS P6T motherboard. Any ideas?
Re: Intermittent Micro Lite problem
Same here.
No solution found.
No solution found.
I solved it by going through a powered USB hub (which of course means the Micro Lite is always on).
I've been having the same issue. So far, only once in a while, and if I disconnect and reconnect the micro lite it's fine.
So it never happens with the powered hub? Interesting, and worth a try. Performance is the same as direct connection?
Sent from my Droid using Tapatalk
It's certainly good enough for me. I have a keyboard and a Mixed Logic M24, and I don't have any problems.
