glitch when clicking on inserts
GWJen
Post by GWJen »
When I click on an insert to open a plug-in window the audio glitches in the form of a short drop out. And on the trim plug-in I can get a quick burst of extra volume. I've tried all different buffer settings besides my usual 1024. This will happen even with only one track in the mixer. I find this distracting and a bit unprofessional. I'm using a dual 2.0 Mac G5 PPC running 10.5.8, 4 Gigs RAM, PCI-424 card, DP 7.22. Thanks for any suggestions!
G5 dual 2.0 GHz, PCI424, 2408x1, 1224x2, UAD-1
stephentayler
Re: glitch when clicking on inserts
Post by stephentayler »
Try running the plugins in real time. This glitch is usual when the plug switches from real time when open, to pre-rendered when closed. You can choose which way you prefer to work, either for individual plugins, or globally.
I prefer to have my preferences set to Run All Plugins in Real Time.
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Killahurts
Post by Killahurts »
What Stephen said. Could also be the delay compensation calculating.
GWJen
Post by GWJen »
Yes Yes! That was it...needed to be in real time mode. Thank you so much.
