I am not getting far figuring out how to route the reverb in what would be post fader on a normal mixer. When I mute an input in the main mix, i still hear the reverb effect. I would like it to go up and down with the fader.
Any tips? (i struggle with an analog mixer too!)
CuemixFX reverb routing
Re: CuemixFX reverb routing
Just to clarify, if I have reverb effect on input 1, and i bring the input one fader down completely, I dont want to hear anything, but i hear the wet signal still. If I apply the reverb to the outputs, it works, but then I have reverb on everything in the mix, not just the input I would like it on.
The reverb send is always pre-fader.
I think (not completely sure - don't have it setup right now) if you use the mix buss send rather than the individual channel send it will do what you want. Put input one on its own mix bus. I think you need to set the split point on the reverb tab also to mix - not sure. If you have a loop then set the mix point to whatever the other choice is.
DP8.06 PT11.2.0 VEP 5.3.x
You have to use the reverb sends and returns.... not the volume fader.....
