AbsolutelyMIDI Life Crisis wrote:Even if you must say so yourself...slotz71 wrote:Not that my mixes suck, because they don’t. My mixes rock!
slotz71 wrote:AbsolutelyMIDI Life Crisis wrote:Even if you must say so yourself...slotz71 wrote:Not that my mixes suck, because they don’t. My mixes rock!
Amp, I could be wrong on this, so please feel free to correct me. I can option-drag a soundbite, but if I select a portion of a soundbite I can only copy/paste. So, aren't the two functionally different? I'm just trying to wrap my head around this. If you CAN option-drag a selected portion of a soundbite, what's the trick? I must be doing something wrong.amplidood wrote:The one fact that makes it clear where the problem lies is that if you option-drag data (thus copying it), the glitch doesn't happen. If you copy-paste it using key commands, it does glitch. There are obviously 2 different sections of DP's code that handle these actions. One is efficient, and one is not. Perhaps the buffering code that is invoked while option-dragging should be called upon when using copy-paste as well.
...Just because you can do something doesn't mean you should do do that thing.
A lot goes on (as indicated above) in the process. RAM is accessed, processors engaged, drive heads spitting info to and from the disk - all on top of the stuff that happens just to play audio (communication to FW devices, Core Audio and MIDI calls, etc.Just because you can't do something doesn't mean you should be able to do that thing.
Or perhaps you just didn't get the answer you wanted. Here is what MOTU considers advanced editing.slotz71 wrote: MIDI Life... sorry, you just haven't contributed anything to the conversation worth responding to...
Nope, but it rocks (especially in SoCal)Timeline wrote:It's not a perfect world now, is it?
Yes, I have had this and numerous issues with DP over the past years. On three different systems, from 10.5.8, Dual G4, dual G5 PPC, Dual core intel. I used to work at a higher education establishment as a studio tech with numerous Digi HD rigs and DP was never stable there too-if you could even get DP to work at all. Trying to fix issues over the years, I purchased at least 3) PCI-324 cards, 2) PCI-424, multiple interfaces. I've continued to throw money at DP, and HD's and RAM (all of which were tested to be working OK). I skipped from DP 4, didn't bother with DP 5 all together, went to DP 6, same instability. Many of you report stability with intels, 10.6 and DP 7-AWESOME!!! Yet, I still read many of you with DP 7 are reporting the same issues I've seen over time. At this point, from what I have witnessed with DP; there is no way I can be convinced that all these systems were bad, or I've been doing something wrong and didn't understand how DP works, or faulty RAM was the blame, etc, etc. etc.slotz71 wrote:I’m trying to find out if anyone else out there is having or has had similar issues, if this is a known issue and people have always just dealt with it, or am I the only person that has been plagued with this issue for the last 6 – 7 years.
