Buying New Mac - Can't Decide
New 2.4GHz 8-Core "Westmere", New 3.33GHz 6-Core "Westmere", or Refurb '09 2.93Ghz 8-core "Nehalem"?
Which one would work best with DP?
I've only found a benchmark test for Logic, and it suggests the '09 2.93 8-core is the best of the three. From what I've gathered though, it's not geared up for the 6-core yet... Is DP?
Benchmark test:
http://www.gearslutz.com/board/music-co ... ktest.html" onclick="window.open(this.href);return false;
...or should I find a way to get the 12-core?
Benchmark test:
Re: Buying New Mac - Can't Decide
The 12-Core 2.93 appears to be a top performer over the the 6-Core Westmere 3.33 if Barefeats findings are to be trusted. For the sake of longevity, I'd go for the Westmere over the Nehalem, but that could be just me.
http://www.barefeats.com/wst10.html" onclick="window.open(this.href);return false;
The question remains how well DP does on each. There have been a couple of other threads on which machine is best for DP and responses have leaned towards "more cores, more better".
Buying the best machine you can afford-- or getting the best machine you can't afford *not* to have is still a good practice.
Good luck.
Good luck.
Interesting: the Barefeats test is a little different than the GS one, but both show the '09 2.93 8 core beating the '10 2.4 8 core, and '10 3.33 6-core.
The (almost affordable) 2.66 12-c scored very close to the 2.93 12c (in that test).
It's how DP takes advantage of these configs is what I'd really like to know.
- sdfalk
Shouldn't it be "how" DP will sooner rather then later take advantage of all 12 cores.
If the system and the application is properly optimized , won't that make a more significant
difference over time?
A Metric Halo ULN8-3D…mmmmmmm
Hi, Here are some conclusions I came to between the 6-core 3.33 and 8-core 2.4ghz: viewtopic.php?f=26&t=43357 (check out my 9/8 post in that link) and viewtopic.php?f=26&t=43100. Since I wrote that, Macperformanceguide.com updated their research to show Logic fixed issues with the 6-core and the performance was dramatically increased. The 8-core 2.93ghz might be the way to go, but if you are not maxing out the track counts all the time, the faster processor of the 6-core might give you better performance with VI's. The 2.93 has been on Apple's refurb page for a good price recently, too. I bought the 6-core with 10GB RAM and so far I am very happy with its performance with DP creating full orchestral sequences with Vienna Instruments samples. Good luck!Tim wrote:New 2.4GHz 8-Core "Westmere", New 3.33GHz 6-Core "Westmere", or Refurb '09 2.93Ghz 8-core "Nehalem"?
Benchmark test:
http://www.gearslutz.com/board/music-co ... ktest.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
iMac 20,1 10-core, 3.6Ghz, OS10.15.7, 128GB RAM, DP 10.13, VEP7
Thanks all for the helpful info.
I found a refurb 12 core 2.66 that I think I'll go for. Hopefully that'll be better than the others (except the 12 core 2.93, which I can't quite swing at the moment).
Methinks you're gonna' be lovin' the 12 for DP... the only downside is probably slightly slower perfomance than the 6 core for non-multiprocesser aware software. Regardless, I'm feeling a mighty Jonesing right about now.
The 12-core is doing me right. Incredibly powerful machine.
I almost got the 6-core because of the faster processor clock speed, but it felt like a "temporary" solution. I just knew I'd be able to stay in the 12 for longer. Both the 6 and the 12 core have 1333MHz. RAM, and that was a bigger factor for me than the clock speed. The other reason is because DP can actually use all those cores. So then it comes down to simple math:
2.66 GHz. X 12 = 31.92
3.33 GHz. X 6 = 19.98
Tim, of the three you listed, the 6-core will win with DP, no question.
Oh.. well there you go!!Tim wrote:I found a refurb 12 core 2.66 that I think I'll go for. Hopefully that'll be better than the others (except the 12 core 2.93, which I can't quite swing at the moment).
you can also check out the geekbench scores -
http://www.primatelabs.ca/geekbench/mac-benchmarks/" onclick="window.open(this.href);return false;
In the scoring, for example, my Quad G5 mac scored around 3000, my Mac Pro 2.26 8 core around 12000, and the latest Mac Pros 12 core, around 21-30,000.
- hammerman
I got the 6-core and couldn't be happier. This is coming form a 7 year old G5 (1st gen!). Dual 2 GHz to 6 3.33 GHz. And the machine is quieter. Loaded it up with 3 8 GB sticks o' RAM. A smooth transition (albeit lengthy) one.
I bought the 2.8 quad-Core Nehalem last September after my dual 2.7 PPC took a dirt nap. I loaded the new machine with 16 gigs of RAM. Not impressed at all. I'm a heavy user of VI's and I like running, MachV II, Trillian and Omnisphere as well as Ableton LIVE at the same time. Because of DP's 4 gig RAM limit, my machine chokes just like the G5.
.....waiting for 64 bit.
DP 5.13 dual G5 2.7 synced to dual 1.42 via SMPTE, Muse Receptor (filled with Stylus RMX, Trilogy, Atmosphere, Elektrik piano, Disco DSP), OSX.410, Ableton LIVE, Apogee Big Ben, Apogee mini DAC, MachV, Symphonic, Ethno, M-Tron, Mx-4,Latigo, Jupiter Vi, iDrum, Microtonic, Kontakt3, Bassline, Bassline Pro, Ultra Focus, Novation Basstation, Novation Drum Station, Nord Lead2, JD-990, EMU Proteus, Orbit 2, MicroKorg, UAD, Poco, Altiverb, VW2, Waves, Ozone, to name a few
Just got a Westmere 2.4ghz 8 core. Once I'm finished a project on my G5 Quad, I'll report on how DP does on the new machine.
DV
DV
Mac Studio Ultra 64gb; Motif 8; Novation Summit, Yamaha MOXF6, Mach Five Three; Altiverb, UVI Stuff, Acoustic Legends; Plugsound Pro; Fender Strat; Stylus, Omnisphere 2.8, Trillian
- silkytom
Not that it is completely accurate (and obviously doesn't take DP into account), but I've found this ok as a VERY rough guide, especially as it includes geekbench scores in the listings.
http://www.everymac.com/ultimate-mac-co ... rrent-macs" onclick="window.open(this.href);return false;
DP user since 2.7
Very late adopter with a range of setups.
Main rig firmly resides in a "rock solid DP7.24 on 10.6.8" past.
