After I drag and drop a measure from EZD into a track, too often when I paste a file it combines with the prior one and I have to delete both measures. I can paste 20 measures for example, then one will just combine with the prior. This only happens in DP. I have tried zooming out, etc. Any idea what I am doing wrong?
Also is there anyway to recall the name of a groove you put in a song, besides maybe putting the info in the tracks comment field? Thanks.
EzDrummer Pasting Issue
Re: EzDrummer Pasting Issue
Could it be... If you are dragging the EZ MIDI file into the track editor-is this when they copy OK back to back? And perhaps, when they are overlapping you are dragging into the sequence editor? Check that out. Hope that helps.garby wrote:After I drag and drop a measure from EZD into a track, too often when I paste a file it combines with the prior one and I have to delete both measures. I can paste 20 measures for example, then one will just combine with the prior. This only happens in DP. I have tried zooming out, etc. Any idea what I am doing wrong?
As I remember I always put the EZ MIDI file info into the tracks comment field.garby wrote:Also is there anyway to recall the name of a groove you put in a song, besides maybe putting the info in the tracks comment field? Thanks.
Ciao
*Dual 1.25 G4 2GB RAM/OS 10.5.8/DP 4.6.1/UAD-1/Powercore/Virus PoCo/NI/ EWQL/MX4/Symphonic Instrument/Novation V-Station,Nova/Green Oak-Crystal, Orbit, Dark Star
*Dual 2.0 G5 PowerPC 6GB RAM/OS 10.5.8/PT 8/DP 6/UAD-1/Powercore
*Core Duo 1.83 Macbook Pro/OS 10.5.8/PT 8/DP 6 and um....
*5) ultra bad Strats/Egnater Tourmaster 4100/Carvin Legacy/Laney 100W AOR/4x12 Celestions
*Neumann/AKG/Shure
http://home.comcast.net/~keith_henry/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;"
*Neumann/AKG/Shure
Thanks for the reply Keith.
But visually I can then paste just 1 or a couple of measures and everything will jump back and look correct. Not always though, and correct playback isn't guaranteed.
Dragging measures in can do it also, if instead of pasting I just keep dragging the measure in. I don't understand it. I wouldn't mind so much if it didn't effect the MIDI track, but it's a hit or miss when they combine if they play back ok.
Nope. It's in the Track Editor. I've been Copy and Pasting/Paste Repeat, etc and it keeps doing this. It's strange that I can paste 5 times then the 6th and 7th combine. I did a paste repeat for 60 measures or so and it only combined the last couple of measures.Could it be... If you are dragging the EZ MIDI file into the track editor-is this when they copy OK back to back? And perhaps, when they are overlapping you are dragging into the sequence editor? Check that out. Hope that helps.
